Guides Section Index
The Basics
Basic mechanical principals and tools - http://306oc.co.uk/forum/showthread.php?tid=32
Jacking and Support - http://306oc.co.uk/forum/showthread.php?tid=33
Peugeot Service box Access - http://306oc.co.uk/forum/showthread.php?tid=86
Guide Section Tips - http://306oc.co.uk/forum/showthread.php?tid=2558
Oil advice & recommendations from oilman @ Opie Oils - http://306oc.co.uk/forum/showthread.php?tid=3378
Servicing
HDi Servicing - http://306oc.co.uk/forum/showthread.php?tid=35
Replacing lower engine mount in situ http://306oc.co.uk/forum/showthread.php?tid=5421
Servicing a petrol 306 - http://306oc.co.uk/forum/showthread.php?tid=9004
How to clean intank strainer/filter - http://306oc.co.uk/forum/showthread.php?tid=11418
Diagnostics/Fault Finding
Testing petrol engine sensors - http://306oc.co.uk/forum/showthread.php?tid=67
Remote Key Re-Syncing - http://306oc.co.uk/forum/showthread.php?tid=1646
Resync ph3 keys - http://306oc.co.uk/forum/showthread.php?tid=2518
Using Peugeot Planet - http://306oc.co.uk/forum/showthread.php?tid=2752
Peugeot ECU BSI units - http://306oc.co.uk/forum/showthread.php?tid=3128
Diesel - XUD
Stage 1,2,3 diesel tuning - Basic Explinations - http://306oc.co.uk/forum/showthread.php?tid=34
Mid box to back box conversion - http://306oc.co.uk/forum/showthread.php?tid=36
FMIC Theory - http://306oc.co.uk/forum/showthread.php?tid=40
BOSCH PUMP VE GUIDES - Gov-mod. - http://306oc.co.uk/forum/showthread.php?tid=79
BOSCH VE GUIDES - LDA modifications - http://306oc.co.uk/forum/showthread.php?tid=131
Reaming your turbo - http://306oc.co.uk/forum/showthread.php?tid=140
BOSCH VE GUIDES - Pump setup and fine tuning - http://306oc.co.uk/forum/showthread.php?tid=145
HP Pump rebuild - http://306oc.co.uk/forum/showthread.php?tid=151
BOSCH VE GUIDES - 11mm Hybrid Bosch Pump + Gov Mod - http://306oc.co.uk/forum/showthread.php?tid=212
Turbo Rebuild - http://306oc.co.uk/forum/showthread.php?tid=1681
Injector Pump Change Video Guide (Bosch Conversion) - http://306oc.co.uk/forum/showthread.php?tid=2145
Bosch VE Video Guides! - http://306oc.co.uk/forum/showthread.php?tid=2398
Bosch Pump - Numbered Guide - http://306oc.co.uk/forum/showthread.php?tid=2942
D Turbo Guides: Injector Leak off's - http://306oc.co.uk/forum/showthread.php?tid=3089
D Turbo Guides: Rocker Cover Gasket - http://306oc.co.uk/forum/showthread.php?tid=3090
Fuel filter change HDI - http://306oc.co.uk/forum/showthread.php?tid=3171
turbo cleaning - http://306oc.co.uk/forum/showthread.php?tid=7239
306 FMIC FAQ http://306oc.co.uk/forum/showthread.php?tid=8172
Bosch - VE Pump Technical Manual - http://306oc.co.uk/forum/showthread.php?tid=82728
Testing Glow Plugs - http://306oc.co.uk/forum/showthread.php?tid=10902
Diesel - HDi
HDi Injectors - http://306oc.co.uk/forum/showthread.php?tid=5399
Fitting injectors hdi - http://306oc.co.uk/forum/showthread.php?tid=7505
Resetting your ECU (HDi) - http://306oc.co.uk/forum/showthread.php?tid=9003
Trip Computer Guide (HDI) - http://306oc.co.uk/forum/showthread.php?tid=9957
HDi TPS repair guide (Throttle Position Sensor) - http://306oc.co.uk/forum/showthread.php?tid=9969
HDi Engine management information - http://306oc.co.uk/forum/showthread.php?tid=478
If your HDI cuts out or feels under powered - http://306oc.co.uk/forum/showthread.php?tid=1497
HDi De-Cat - http://306oc.co.uk/forum/showthread.php?tid=41
Stage 1 HDi - http://306oc.co.uk/forum/showthread.php?tid=42
Stage 2 HDi - http://306oc.co.uk/forum/showthread.php?tid=43
Petrol
How to fit a gti inlet manifold to a 1.816v / 2.016v - http://306oc.co.uk/forum/showthread.php?tid=161
GTI6 Ph2 engine loom drawing http://306oc.co.uk/forum/showthread.php?tid=32571
Suspension
Fitting upper and lower strut braces - http://306oc.co.uk/forum/showthread.php?tid=109
Front suspension/spring/coilover change - http://306oc.co.uk/forum/showthread.php?tid=2007
DIY 306 Rear Beam Rebuild - http://306oc.co.uk/forum/showthread.php?tid=8782
Lowering rear suspension - http://306oc.co.uk/forum/showthread.php?tid=8933
FAQ: Rear Beam Camber & Toe Specs - http://306oc.co.uk/forum/showthread.php?tid=9090
Manufacturing an upper strut brace - http://306oc.co.uk/forum/showthread.php?tid=10438
[How to] Manufacturing an upper BAR 306 - http://306oc.co.uk/forum/showthread.php?tid=10440
[How to] Make Rigid axle mounts 106,205,309 - http://306oc.co.uk/forum/showthread.php?tid=10520
[How to] Assemble triangulated rear axle PSA - http://306oc.co.uk/forum/showthread.php?tid=10522
[How to] - Optimize PSA rear axle - http://306oc.co.uk/forum/showthread.php?tid=10523
[How to] Stiffen the front end 306 & ZX - http://306oc.co.uk/forum/showthread.php?tid=10546
Wiring, Audio & Electrical
MOD: Fog flash with main beam - http://306oc.co.uk/forum/showthread.php?tid=143
Sound deadening a 306 - http://306oc.co.uk/forum/showthread.php?tid=227
The Audio Big 3 - http://306oc.co.uk/forum/showthread.php?tid=382
Door Card removal / Crossover install - http://306oc.co.uk/forum/showthread.php?tid=2567
The Audio BIG 3 - http://306oc.co.uk/forum/showthread.php?tid=2830
How to replace a faulty twin fan motor - http://306oc.co.uk/forum/showthread.php?tid=7432
HID flicker fix guide http://306oc.co.uk/forum/showthread.php?tid=8430
Re programming a key fob - http://306oc.co.uk/forum/showthread.php?tid=9015
ph2/3 rear lights into ph1 diagram - http://306oc.co.uk/forum/showthread.php?tid=9265
Ph2 and 3 Wiring Diagrams - http://306oc.co.uk/forum/showthread.php?tid=9993
HDi Wiring Diagrams http://306oc.co.uk/forum/showthread.php?tid=10000
Replacing 306 Broken Door Loom - http://306oc.co.uk/forum/showthread.php?tid=11512
Instrument Panel Warning lights and symbols - http://306oc.co.uk/forum/showthread.php?tid=77
Twin Fan Wiring - http://306oc.co.uk/forum/showthread.php?tid=5185
Faulty Airbag Bypass - http://306oc.co.uk/forum/showthread.php?tid=12557
Interior Modifications
Sticker Bombing - http://306oc.co.uk/forum/showthread.php?tid=107
How to make a black roof lining - http://306oc.co.uk/forum/showthread.php?tid=185
Electric Dimming Rear View Mirror - http://306oc.co.uk/forum/showthread.php?tid=1302
Stopping your squeaky blowers - http://306oc.co.uk/forum/showthread.php?tid=1478
Fitting Plasma dial face's - http://306oc.co.uk/forum/showthread.php?tid=1942
Gear Knob Removal - http://306oc.co.uk/forum/showthread.php?tid=2712
Fitting a boost gauge in driver's side vent. - http://306oc.co.uk/forum/showthread.php?tid=2940
Centre console facia removal - http://306oc.co.uk/forum/showthread.php?tid=3108
Guide: Steering Wheel Removal/Fitting (including airbags & bosses) - http://306oc.co.uk/forum/showthread.php?tid=9712
Guide: Removing the Instrument Cluster, Replacing Bulbs, Fitting Dials - http://306oc.co.uk/forum/showthread.php?tid=9781
Making A Trip Computer Stalk - http://306oc.co.uk/forum/showthread.php?tid=10213
Removing Door Cards - http://306oc.co.uk/forum/showthread.php?tid=11609
Bodywork, Painting and Exterior Modifications
GTi6 Spliter Fitting - http://306oc.co.uk/forum/showthread.php?tid=39
Dewipering - http://306oc.co.uk/forum/showthread.php?tid=192
Tinting Rear Lights - http://306oc.co.uk/forum/showthread.php?tid=916
How to paint fake splits - http://306oc.co.uk/forum/showthread.php?tid=1630
De-Locking Your Boot. - http://306oc.co.uk/forum/showthread.php?tid=2159
Delocking your boot - http://306oc.co.uk/forum/showthread.php?tid=3492
Valeo black mask guide! - http://306oc.co.uk/forum/showthread.php?tid=6937
Guide - Removing Front Bumper - http://306oc.co.uk/forum/showthread.php?tid=7361
306 Wing Modification/Arch Rolling - http://306oc.co.uk/forum/showthread.php?tid=10544
[How to] Improve aesthetics ZX & 306 - http://306oc.co.uk/forum/showthread.php?tid=10545
Snow foaming your car - http://306oc.co.uk/forum/showthread.php?tid=2551
Application of Rain-X - http://306oc.co.uk/forum/showthread.php?tid=2833
Front and Rear seat removal - http://306oc.co.uk/forum/showthread.php?tid=147
Exhaust Sound - http://306oc.co.uk/forum/showthread.php?tid=255
How to fit a new clutch cable - http://306oc.co.uk/forum/showthread.php?tid=844
Useful Part Numbers - http://306oc.co.uk/forum/showthread.php?tid=986
How to fit an Oil Cooler (Badly) - http://306oc.co.uk/forum/showthread.php?tid=1403
Fitting a quickshift - http://306oc.co.uk/forum/showthread.php?tid=1477
syphoning fuel made easy - http://306oc.co.uk/forum/showthread.php?tid=2496
Wheel Weights - For Guide - http://306oc.co.uk/forum/showthread.php?tid=2788
Make a 306 Meridan/Gti6, 5 speed key-ring! - http://306oc.co.uk/forum/showthread.php?tid=2863
Using club meme's. - http://306oc.co.uk/forum/showthread.php?tid=3163
Dual Horns - http://306oc.co.uk/forum/showthread.php?tid=3307
Car Insurance - Postcode Risk - http://306oc.co.uk/forum/showthread.php?tid=4436
Guide to replacing the Bosch 5.3 ABS pump and module - http://306oc.co.uk/forum/showthread.php?tid=5124
Guide: Life - Part 1 - http://306oc.co.uk/forum/showthread.php?tid=5899
Gearbox, diff & transfer box recommendations HERE > - http://306oc.co.uk/forum/showthread.php?tid=8156
RE: quickshift - http://306oc.co.uk/forum/showthread.php?tid=8831
306 Safety recall information - http://306oc.co.uk/forum/showthread.php?tid=9999
Cold weather gear changes - http://306oc.co.uk/forum/showthread.php?tid=10043
RE: [How to] - Lighten a car for more Power !!! - http://306oc.co.uk/forum/showthread.php?tid=10503
[How to] Plan 306 Quickshift - http://306oc.co.uk/forum/showthread.php?tid=10521
Clutch problems - read this first! - http://306oc.co.uk/forum/showthread.php?tid=11543
Thanks given by: -ER-
None of the links work, well the ones I want to view that is
Confused
you can still view the guides in the guides section. Old threads cannot be accessed with their old links. this should be fixed soon.
All updated and working Smile
What are the requirements to access the servicebox thread?
Do you mean access service box website?
Just make a false account
Edit. I should read things properly whoops
No. The thread here in the guides section. When I click it, I get this message:
You do not have permission to access this page. This could be because of one of the following reasons:
Your account has either been suspended or you have been banned from accessing this resource.
You do not have permission to access this page. Are you trying to access administrative pages or a resource that you shouldn't be? Check in the forum rules that you are allowed to perform this action.
Your account may still be awaiting activation or moderation. (Resend Activation Code)
You have accessed this page directly rather than using appropriate forms or link.
So was wondering if you had to be a paying member or something? Assuming that this thread is the one that has the club login info(if the club still has an account).
What's the score with Servicebox access please? I also get the "You do not have permission to access this page. This could be because of one of the following reasons" etc page. Cheers
EDIT: just saw the "make up a false account" duh sorry
  Multiple Youtube Guides for Pug306 timpug 3 3,253 12-06-2015, 11:15 PM
Last Post: 7057sam
  BOSCH PUMP VE GUIDES - Gov-mod. Dan! 34 37,227 20-05-2014, 04:49 PM
Last Post: 205steve
  BOSCH VE GUIDES - LDA modifications Dan! 30 76,580 28-06-2013, 11:51 PM
Last Post: samass
