guide resync ph3 keys
pdf file from autodata
explaining the resync proscess
.pdf   sync ph3 key.pdf (Size: 26.91 KB / Downloads: 331)
Sweet ill give that a go later Smile
Need new a new battery and it isnt the same as the older fobs >.<
Wait.... does this mean all th time Ive been single locking my car that the alarm hasn't even been active? Doh
Never wanted to double lock it as i always assume the battery will die and ill be locked out!
SRowell Wrote:Wait.... does this mean all th time Ive been single locking my car that the alarm hasn't even been active? Doh
Youre a twat... you know that silver round thing on the door? Thats a key barrel, you know what goes in there? A key. Funny that lol
Youre a lady garden... you know that silver round thing on the door? Thats a key barrel, you know what goes in there? A key. Funny that lol
i thought if you double locked it it disabled those? Or am i thinking of our freelander :pray:
No it disables the door mech on the inside, you can still unlock it with the key, just the same as you can double lock it with the key
How do i do the single button Ir remote?
Theres a single button? O.o
This type
[Image: DSC00919.jpg]
Never seen one of those before lol I assume itll be the same as the other IR remote, key in the barrel and point the fob at the sensor
search down the guides there is another post about key syncing
Connor Wrote:Never seen one of those before lol I assume itll be the same as the other IR remote, key in the barrel and point the fob at the sensor
Peugeot, in all their infinite wisdom, made IR keys universal across the 106, 206, 306 and 405 ranges (maybe..)
This may well have come from a different model at some point Smile
Captain Standard
Sam....check your lock barrels actually work lol....I find on a lot of RCL cars they're so rarely used they get stuck closed! :o
My diablo had a key stuck in one side, no boot lock being a ph3 and the pass side lock kept jamming up....that was fun! Until one day the RCL just worked again. Confusedhock:
Same on the silver golf, the boot lock and pass side door lock are both stuck.
No thats just poorly maintained cars, as the barrels should be getting sprayed with grease on the service atleast once a year
I have one button too but dont work :/
[Image: sign.png]
↑ Project ↑
Well this didn't work Sad
Matt Wrote:Well this didn't work Sad
That's because it's only a resync. You need yours programmed by the sounds of it.
Fair enough, still haven't had a reply from that guy niall
