Door Card removal / Crossover install
im installing some "Vibe EDGE ED306" crossovers (linky.. http://www.caraudiodirect.co.uk/edge-street-ed306.html)
before installing these ive mounted the tweeters in a direct replacement for standard ones
so a before shot..
[Image: IMG_20120402_125049.jpg]
start by popping off the cover and unscrewing using a T25 Torx the 4 speaker screws
[Image: IMG_20120402_134214.jpg]
next, using a flathead screwdriver, remove the window switch and disconnecting
[Image: IMG_20120402_125153.jpg]
[Image: IMG_20120402_125232.jpg]
Once removed there should be a T30 Torx behind to remove
[Image: IMG_20120402_125502.jpg]
2 more T30 to remove, one found behind a rubber bung
[Image: IMG_20120402_125520.jpg][Image: IMG_20120402_125406.jpg]
remove the door handle surround trim (already removed in my pics)
then get in between the card and the door metal and prize it all apart, theres quite a few clips running the perimeter of the door card
[Image: IMG_20120402_125618.jpg]
pull away from the bottom like so..
[Image: IMG_20120402_125659.jpg]
then lift up to remove
and in true haynes style....refit is opposite to removal
Speakers
mine came with a small crossover unit to be put behind somewhere, using the double sided sticky pad provided i wedged mine up here
[Image: IMG_20120402_130553.jpg]
and connected to the speaker wires
[Image: IMG_20120402_130228.jpg]
and connected one of the feeds to the door speakers and the other to the tweeters
[Image: IMG_20120402_132034.jpg]
wedged all the wires back in the whole and put it all back together Big Grin
[Image: IMG_20120402_145557.jpg]
Useful links
door trim clips part number : 6966 39
and the speakers i used, highly reccomended for budget Big Grin
nice one. what speakers are they?
Edge ED306's Smile
http://www.halfords.com/webapp/wcs/store...yId_165707
Captain Standard
I have two of these sat in the box at home, just the speaker though no tweeters lol
Did you only buy them because they had '306' in the name? lol
I have these speakers and they are a great upgrade!
i thought it was them, been scanning halfrauds for some cheap but decent speakers
If you can find some tweeters and crossovers then you can have my ones for free lol. Just want them gone lol
sounds good! ill get on the hunt for them then! cheers man!
linky, theyve gone down in price and are a bargain!
i did buy these like 2 years ago though lol
also paired up with these 6x9's
http://www.vibeshop.co.uk/product/Black ... blackair69
now all is needed is a subwooooffa
even cheaper there than at halfrauds with a discount!
They look too deep to fit in the door properly?
Shame you couldn't of bought some decent speakers eh? Lol
Niall Wrote:They look too deep to fit in the door properly?
they fit Big Grin probably just but they do Big Grin
theyre not bad speakers tbf
Anyone know the part code for the clip things which go into those holes? Mine are buggered and come un-popped every single day when you pull the door closed.
[Image: sigjpg.jpg]
Serious.
I'll add that to the op later as useful info :-)
Can you still put the speaker cover over the speaker once you have the Edge one fitted?
[Image: 306oc.jpg]
I could Smile don't see why not Wink
So the speaker isn't too big then to fit it back on?
Going to buy myself some but want to keep them covered
[Image: 306oc.jpg]
Nope direct replacements
I have some in the garage somewhere but iirc they don't quite fit. They pop out quite easily but if you get a bit of blue tac or something.in the hole then it.should be fine
The fli components are a good fit for same ish money
I've just brought myself some of the Edge ones, and I want to keep them covered, but I was told that it's hard to find some speakers that do fit the 306's
[Image: 306oc.jpg]
Yeah because they have over shallow mounting depths
Like I say its probably doable but when I had mine on there they get knocked off easy
The fli (comp6 iirc) components fit alright
I had edge ones in mine and they seemed fine? Sure yours wernt over loose ?
Were they ed306 component? And no they're not loose :-)
Yep. Remember loling at the 306 part
Well I'm going to have some fun fitting my speakers in the doors cos I've just won some Boston Z6's on eBay looks like its door builds for me :o
Thinking about it, my door cards have alot of the plastic cut away inside. But that shouldn't make a difference surley
how did you get the new tweeters to fit in the original tweeter bit?
[Image: 306oc.jpg]
I undone the old one taking out the 2 screws removing the tweeter. Putting the new one in then screwing the old screws 50% in and looping an elastic band round a few times.
Its held there for 2 years now
  Guide: Dashcam Mirror power supply: USB charger install toseland 1 2,279 26-07-2016, 09:03 PM
Last Post: Mattcheese31
  GUIDE: PS2 Install Eeyore 6 7,519 02-02-2014, 04:01 PM
