D Turbo Guides: Rocker Cover Gasket
Quick guide for changing the rocker cover gasket. Some of this may apply to other models such as the NAD but this guide is aimed at the DT so adjust to suit.
Symptoms: Oil around the top of the engine, usually noticeable down the back.
Cause: Failed gasket.
Tools needed: (intercooler)6mm allen key,13mm socket, flat head screwdriver
(rocker cover)10mm socket, 8mm socket
Parts needed: Rocker cover Gasket (obviously), d-seal.
First task is to get the intercooler off, explained here. Once off you need to remove a fuel line bracket with an 8mm socket (just off picture, green arrow). Slacken off and remove the breather pipe (blue) then remove the 3 bolts securing the cover (red). Loosen each one of gradually and recover the fuel line bracket on the cam pulley end as you remove them.
[Image: img20120428170009.jpg]
Once all the bolts are out carefully pull the cover off to reveal the cam shaft. With the cover away from the engine start separating the old gasket from the cover, mine had gone like a rigid plastic and snapped off into 4-5 bits. Clean up both surfaces with a rag and fit the new gasket. Not sure if this was needed but I put a thin layer of fresh engine oil all the way round the gasket to help it seal.
[Image: img20120428171216.jpg]
[Image: img20120428171303.jpg]
Finally put the cover back on and get the bolts in finger tight, set your torque wrench to 20 Nm and tighten them from the middle out, again the Haynes says nothing of the tightening sequence but seemed to make sense. Note: Over tightening the rocker cover bolts will ruin the brand new gasket you have just fitted!
[Image: img20120428173228.jpg]
Replace intercooler with a new d-seal.
Done.
HDi Cabby Project Click
Good Guide, I run a 6 bar oil pump spring and have only ever been able to get this to seal by using some gasket seal on either side of the new gasket.
CJ
[Image: J5hxCcC.jpg]
Also when removing the old gasket I like to run a Stanley around the edge and get it properly clean before putting the new one on :-)
My bad Blush i have overtighting the new rocker cover gasket, 1 month ago must i trow itt away and get a new one? ore can i losen the bolts to 20 nm?
Thanks for answer Smile
[Image: 62941977.jpg]
(02-09-2012, 09:40 AM)306__xrdt Wrote: My bad Blush i have overtighting the new rocker cover gasket, 1 month ago must i trow itt away and get a new one? ore can i losen the bolts to 20 nm?
Chances are you will have ruined the gasket, been there myself mate. At least they're not too expensive.
Already bought a new one but to bad they dont have seal for the intercooler ebay might do the trick Smile
(03-09-2012, 11:19 AM)306__xrdt Wrote: Already bought a new one but to bad they dont have seal for the intercooler ebay might do the trick Smile
yes they have them . . .there you go . .Smile
http://www.ebay.co.uk/itm/Citroen-Peugeo..._500wt_969
Dose anyone know the part number for the breather pipe marked in blue
Already bought one Smile
(03-09-2012, 08:36 PM)Daniel306 Wrote: Dose anyone know the part number for the breather pipe marked in blue
I have one ekstra breather pipe part number on that one is REF: 504240
not sure if it is correct but you can tray it out Smile
Just seen this guide, I tried tightening mine to 20nm and it sheared the thread Sad
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Mine rocker cover bolts snapped off on 20 nm...so i found new bolts and allot off less nm on this bolts now.
Might be different zise on the rocker cover i quess....Blush
i always finger tight them and then nip 'em round a bit . . .doesn't take much . . Smile
  Guides Section Index Scott 7 30,794 04-10-2018, 01:01 PM
Last Post: balkan_bozo
  Multiple Youtube Guides for Pug306 timpug 3 4,055 12-06-2015, 11:15 PM
Last Post: 7057sam
  BOSCH PUMP VE GUIDES - Gov-mod. Dan! 34 42,128 20-05-2014, 04:49 PM
Last Post: 205steve
