Threads: 198
135
Given 0 thank(s) in 0 post(s)
Hi fellas, will be updating this as I go along, but here's a quick guide for how to PROPERLY refurb fake split wheels and try and make them look half decent!
Right, the problem with fake splits is that the bolts can't be removed, so to paint them you have to pick a masking line away from the bolts. Or paint the bolts too. And that would look crap. Or you could always mask up each of the 30 fake bolts PER WHEEL which, unless you spend years doing it, would also look crap.
If only there was a way to paint the centres as if they were actual two or three piece splits?
Here's the wheel in question. That cheap knock off basterd.
I got a bit carried away today, picked up an 8mm 12 sided socket and thought "hmm, wonder if these are plastic lugs screwed in?"
They aren't.
Snap, dead. Superglue the head back on? Wait a minute..
Turns out that yes, as suspected, they're plastic lugs that are supposed to look like real bolts. And they seem to be glued in pretty well, so they don't pull out and as soon as they twist they snap. But if you take a 6mm drill bit to what's left after snapping the head off...
Here's the wheels all drilled out. Really soft plastic so was a piece of piss removing them all, some even pulled out whole! Loads of plastic swarf everywhere though!
Here's a tip too - use a drill bit for wood, the ones with the bayonet like part at the end of the bit. Helps to centre the drill on the lugs so you don't skew off and destroy the edge of the alloy.
Now start masking up. I found the easiest way for these was to mask all round the edge, then CAREFULLY running a craft knife around the edge of the "barrel" and peeling off the unwanted masking tape. Then just battered bin bags over them to cover the lips and tyres.
Here they are with primer already misted onto them
Then we start adding some colour. I'm using Halfords' own "Diablo Red", apparently, but I've found with a white primer instead of red it looks even LESS like Diablo, and more candy. Result.
Bit of basecoat
Aaaaand then start adding the clear. Lots of clear. Lots of clear is good for two reasons - depth, and flattening. Means if you get any runs you can sand and polish them back, and when shiny they give a HUGE amount of depth to the colour
Then when you're all done, like with my 8 coats or so of clear, off with the masking and look at your nowhere near finished yet a different colour already wheels!
Sorry about the photo quality, camera was set to auto and I had f*ck all natural light left so they've come out pinky. Will get some decent pics in the sun (if it even exists any more?) and post them up.
Now to wait for the bolts...
Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
Given 1 thank(s) in 1 post(s)
Bloody good idea! Will look the shiz too!
Threads: 465
114
Car Model/Spec: Vauxhall
Given 98 thank(s) in 92 post(s)
why dont you blind tap the hole and locktite some anodised alloy cap head screws in there
which is sorta what you said lol
Threads: 448
51
Hmmm wonder if my lensos are they same. If its a plastic cap I'll whip them off. What to replace with though. And where to get them from haha
Threads: 198
135
I'm looking into plating now. If I get proper bolts for BBS' etc, they're about £1+ each. So for 120 bolts that's a bit more than I fancy spending!
Can get 150 stainless M6x10 bolts on eBay for about £18. Stainless will look good but would rather have gold, or even yellow zinc + oil for that rainbow look...
Threads: 32
2
Car Model/Spec: '96 306 1.4
yellow bolts with the center in candy red <3
![[Image: sign.png]](https://lh3.googleusercontent.com/-QC0ySJzJ_vU/Tz-FRT2KPTI/AAAAAAAACDs/caChZQn3zg0/s500/sign.png)
↑ Project ↑
Threads: 117
21
Car Model/Spec: needs bwarrrp.
never thought of doing this. suppose you could even fill the somehow and spray over the lot. good idea though mate.
Threads: 15
There going to look proper nice! I look forward to seeing the estate come together.
Threads: 198
135
Gah not enough natural light so struggling to get a good picture of the colour
Anyway just updating the first post with more pics and stuff
Threads: 198
135
Threads: 22
0
Car Model/Spec: 306 1.4
Looks decent mate! Would be good to see the results!
Threads: 117
21
done a sound job their mate. gonna look mint.
Threads: 48
2
Doing a good job there, i would have been tempted to fill the holes in.
Do the holes go all the way through?
Threads: 93
8
Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
Now, stop me if I'm wrong, but surely you've painted too much?
i.e.
The bit where the bots go through is part of the outer lip and so would stay polished?
Look awesome nonetheless, need some fancy bolts to finish them off, I'm saying gold FTW
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
Threads: 22
0
The original colour has the bit where the holes are painted too!
Threads: 87
31
Kezzieboy Wrote:Now, stop me if I'm wrong, but surely you've painted too much?
i.e.
![[Image: 06.JPG]](http://www.wokke.de/rims/stock/RS197-212/BLACK/06.JPG)
Depends if they are 2 or 3 piece splits. The ones you posted are 3pc
Threads: 386
87
Never understood the point of splits lol, why would you want a load of bolts spoiling your nice smooth wheels!? :?
Anyway, the paint looks good so far mate.
Threads: 22
0
Split rims are amazing! End of!
Threads: 92
43
Car Model/Spec: Tracterrrrrrrrr
Given 2 thank(s) in 2 post(s)
Foxy-jim Wrote:Split rims are amazing! End of!
Theyre really not, but each to their own lol
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Dan! Wrote:Depends if they are 2 or 3 piece splits. The ones you posted are 3pc
Not completely accurate that, it depends if the centers are sandwich or face mounted.
But as a rule, most 3pc are sandwich mounted and most 2pc are face mounted.
Threads: 87
31
Chris Wrote:Dan! Wrote:Depends if they are 2 or 3 piece splits. The ones you posted are 3pc
Yeah I know, didnt want to get too detailed though considering most people on this forum dont go any further than cyclones
Threads: 93
8
I see, fair enough, looks better sandwich mounted then
Threads: 386
87
Connor Wrote:Foxy-jim Wrote:Split rims are amazing! End of!
Haha, agreed!
Threads: 22
0
Threads: 198
135
Kezzie, cheers for pointing that out
As said, 3-piece splits tend to have the polished lip as the outermost piece so would be coloured differently to mine. TBH going off the detail on the wheels it looks like they're 2-piece style reps as the part i've painted red has been made to look like one piece, with the lip appearing to bolt behind it.
Don't get me wrong, genuine splits are full of win but also major $$$$. This isn't a guide to make fake splits look like real splits, it's a guide to strip down a fake split so you can make it a little more presentable. Just highlighting things like that the bolts can be removed so you can paint easier and/or customise more, a lot of people would be reluctant to rip off the bolts if they couldn't be replaced
Threads: 198
135
Bolts are here, all 140 of them. They're stainless steel, but do I keep them silver or paint them gold?
Threads: 117
21
silver has win written all over it.
Threads: 78
49
These look awesome, I think gold would look sweeeet  . I'm tempted to refurb my centres gold at some point, I'll have to see if my "bolts" are the same... Will come in handy if that's the case
Threads: 22
0
Silver bolts and polished lip!
Threads: 198
135
Hmm think am swaying towards gold bolts and gold callipers. Hammerite smooth gold looks lovely, durable too!
