syphoning fuel made easy
quick guide
how to get fuel out of a pumped supplyed car with no aftertaste Big Grin
based on the HDI but the principle is the same for derv or perv
steps..
1. locate fuel supply pipe in engine bay disconnect fitting and fit rubber syphon hose place end of hose into drum
2. Leave ignition OFF! remove tank bung under rear seats unplug pump supply cable
3. connect battery charger across terminals P+ and P- **CAUTION DONT SHORT OUT THE SENDER CONNECTIONS**
4. turn on battery charger fill drum
5. turn off power to stop pump pumping
6. enjoy your fruits
[Image: DSCF0028.jpg]
[Image: DSCF0027.jpg]
[Image: DSCF0029.jpg]
Win! I'm doing this to a few cars soon. Need fuel for the offender
I was really lazy when syphoning off fuel from my sedan that went to scrap ...took off the return pipe from the bosch and just ran the engine, haha. Only took 5 minutes to empty about 35L
Big GrinD
1st - Diablo 306 1.9 N/A Diesel - Failed Gearbox
2nd - Diablo 306 1.9 N/A Diesel - At 225,000 miles the engine fell out
3rd - Diablo 306 Sedan 1.9 Turbo Diesel - Rust bucket
4th - Cherry Red 306 Sedan 1.9 Turbo Diesel - Crashed 6 days after buying, Bah!
There's a fuse under the bonnet you can short to do this, artless there is on the expert van
Megamonkey Wrote:I was really lazy when syphoning off fuel from my sedan that went to scrap ...took off the return pipe from the bosch and just ran the engine, haha. Only took 5 minutes to empty about 35L
Big GrinD
Heh I do this all the time, by far the easiest way to move fuel, we do this out field all the time when one car runs up, just top up from the other Tongue
I didnt think of that, I just keep turning the ignition on and off so it keeps pumping through
Big GrinD
Should be calling you Lazyman Lobb, knows all the tricks! lmao
Going to need to know this once all the fuel has run out!
Video Easy Guide On Installing A Boost Gauge sammyb303 1 2,313 07-06-2015, 08:15 AM
  Guide: Easy to watch video on increasing fuel on the bosch pump sammyb303 7 4,878 03-06-2015, 05:44 PM
Last Post: Pug0BZ3011
