[How to] Improve aesthetics ZX & 306
06-02-2013, 08:47 AM
Everything you've suggested would be a detrimental effect on the standard design of the 306?
**** Modificatons for mounting lights 306 Phase 2 up 3 on 306 Phase 1 :
- Technical changes for front panel mounting 306 Phase 2 / 2.1 / 2.2 / & 3 on 306 Phase 1: - The thin side moldings Phase 2 and Phase Phase can be mounted, you just recover staples (fixing clips side moldings) For installation of the lights on Phase 2 Phase 1 up to 3, a modification of the front crossbar is required as well as a minor modification of the beam connection between phase2-3 to phase 1. - The grille is a slightly modified phase 2 - The bumper is a phase 2 sport - The grille logo is a logo of 605 phase 2, phase 3 (or 2.2) as logo filled **** For mounting side moldings 306 phase 2 / 2.1 / 2.2 & Phase 3 on a 306 Phase 1 : - The rods are 3/4 identical from one phase to another. Lengths of rods are the same assumption or respect fact that it is 3 or 5 doors, 3 to 5 and from May to March it will not. But the side moldings and a 306 phase 2 or 3 go up without problems on a Phase 1. Suffice it to retrieve it or staples clips fasteners model you will mount on your chopsticks. - The phase 2.1 rods are fixed in the same holes as the original phase 1. - There is the stage 2.2, which have a double piercing on the front wings for small chopsticks. - For the installation of lights phase 2 or phase 3 on phase 1,it's necessary to change the front crossmember,change the hood,grille,chopsticks whiskers in the front lights may be either chanhées be changed. - Second solution as above, remove the stripper heat gun and heat the grill and ABS elements for perfectly formed order to move lights, grille, bumper and sticks in the fire,(you will not be too much for these two manipulations). - In short it's quite manageable even for a novice, it's sufficient for appropriate drilling two holes there or manquenront. Then submit clips or staples before fixing holes already present original To fix your old side moldings. This is actually the old V1 offers nice baguettes V2 to V3 not most modern much effort, you will agree. ! ********************************************************** **** Changes to the front cross phase 1 to be able to mount the lights and the front complete 306 Phase 2-3 on the 306 Phase 1 : (06-02-2013, 08:47 AM)JJ0063 Wrote: Everything you've suggested would be a detrimental effect on the standard design of the 306? It is certain that assemble parts on a 306 ZX distorts car by the force of things, but after that is a matter of taste and colors! lool I am altruistic, so I do not think that I otherwise there would only plans, dimensions, calculations and math tests in real conditions on open circuit during the weekend. If you talk to me about compliance with laws, this chapter where I think I when I have no choice and they ask me my papers! loll I am not at all but tuning Racing! Me is the track, asphalt, bitumen, tar, where it Gripp, my 3-6 should take the road like a sucker. The default XUD have a center of gravity lower than that of sports, then lowering the body or frame is can drive a S16-eating ass or some TDi. Handling and speed passage of curves and bends are decisive factors. Long live the good big Diesel engines which weigh much weight, I would signal the passage that it is technically possible to lower a few inches of height side engine mounts and gearbox mount gearbox underneath the battery. Center of gravity lower and optimized aerodynamics = efficiency in handling indisputable.
06-02-2013, 09:20 AM
(06-02-2013, 08:50 AM)fan2xud Wrote: - For the installation of lights phase 2 or phase 3 on phase 1,it's necessary Google Translate is brilliant - I'm assuming this means hockey sticks? Still - massive respect for all the stuff you've posted!
**** Deleting caches colors in your rear brake lights ZX & 306 :
- 306 : - ZX : **** Turn your classic headlights to style lights Lexus or Angel : - http://www.forum-auto.com/tuning/feux-ec...381065.htm **** Making your own lights Angel Eyes : - http://hotridersteam18.top-forum.net/t65...yes-maison **** Transformation fog lights,long range yellow lights to white lights : - http://forum-tuning.fr/passer-de-phares-...-t390.html **** Install rear electric windows on your 306 5 doors : - http://tinyurl.com/306inside1 **** This is a subject to create your taillight LEDs HomeMade : - http://www.forum-auto.com/tuning/prepara...9-1295.htm **** Schémas,croquis faisceau électrique pour branchement anti-brouillards, longues portée sur 306 & ZX : **** To connect buttons window sequential Xantia beam on ZX phase 1 & 2. ---------- *****************************By /\/\3**** (06-02-2013, 09:20 AM)vlj Wrote:(06-02-2013, 08:50 AM)fan2xud Wrote: - For the installation of lights phase 2 or phase 3 on phase 1,it's necessary Scott would normally restore order in everything,,, I'm really sorry to kill your native language so but I promise to do my best friends, snniiffff! I'm so French,,, PS : Go0gle worked better in time to the good old days! looll
06-02-2013, 01:24 PM
I like the led tail lights just wish I could read the French in the guide
06-02-2013, 10:24 PM
I add a little tips gradually.
Translate takes a lot of time because I hurt your language mastery, in fact it takes me too long because there are a lot of words and baths that I do not know, then G00gle does not help us too much in fact. I live in the country and I do not have much flow internet connection. 60K and 15K for dowloads for my Uploads, impossible to upload files larger than 100MB, this bug every time.
07-02-2013, 08:07 PM
chopsticks whiskers lol
good effort anyway!
10-02-2013, 11:59 AM
It was too easy for you so far,lool ...
C'est trop facile cela mes amis !! HiHii ... on va compliquer un peu la tâche à présent,je vais un peu me simplifier la vie. Chopsticks,whiskers ça me fait penser à Whiskas la nourriture pour chats ! lol Google translate does not even know what he has given me as a translation,,, lol |
![[Image: pcarrph2.jpg]](http://img837.imageshack.us/img837/144/pcarrph2.jpg)
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg)
good effort anyway!
