[How to] - Optimize PSA rear axle
** Some useful information (width axles origin PSA):
- 205 GTi 1.9 --> 1344mm
- 309 GTi 1.9 --> 1366mm
- 309 S16 ------> 1378mm
- 306 S16 ------> 1454mm
- 405 Mi16 -----> 1443mm
- Partner ------> 1440mm
- Xsara VTS ----> 1442mm
- ZX Volcane ---> 1415mm
** Throughout this topic, measurements are expressed in millimeters,centimeters
and meters,grams and kilos.
** In first order, it's essential to know that PSA,the or through central
beam-backs and trains are two things well disticnctes, then saw the PSA
range you can imagine ...
- Legend :
1 -> Traverse or beam
2 -> Demis arm or half-axle rear axle
3 -> Turrets rear support
[Image: ghj456.jpg]
** How to mount grease properly on a rear axle PSA:
** Purchase the number of grease that you want to install, I will give you
counsels nipples with metric M6.
Also buy 2 cartridges of grease to fill the cross
after mounting the rear axle nipples.
- In practice this ...
- Drill Ø5 (a little grease on the drill to keep the chips above)
- Tapping M6 (tapping machine).
- Blocking grease with a little loctite the mounting screw, now sealing
and installation of grease is finished.
That's the life of your axle extended especially given the climate in your
country, because it is a major flaw in our range as we call it mode
"Gordini" loool
[Image: 45851690.jpg][Image: 28578847.jpg][Image: graisseurspourtrainarri.jpg][Image: dscf0067ei.jpg][Image: cotespourmontagedegrais.jpg]
** Optimization rear brake calipers and by mounting discs brakes PSA
(Peugeot-Citroen, in this case no difference).
** Changes in media clamps when assembling rockets back adjustable:
- For trains rear drums, it is possible to recover the hubs an axle disc
to re-assemble the caliper bracket axle brakes on your drums.
You will probably change the handbrake cables and add splitter and
compensator brake if not originally equipped.
[Image: trainarriretripistonsni.jpg][Image: trainarriretripistonsni.jpg][Image: trainarriretripistonsni.jpg][Image: etriersfreinsarr405orig.jpg]
[Image: triersavantdebxsurtrain.jpg]
[Image: dscn6795c.jpg][Image: 1317964016.jpg][Image: 1317959642.jpg][Image: photo025je8.jpg][Image: etriersfreinsarr405orig.jpg]
[Image: s5000244mw5.jpg][Image: s5000245kv5.jpg][Image: taorigine205gravecsystm.jpg][Image: taorigine205gravecsystm.jpg]
** Strengthen rear axles PSA triangulation welded, or adapting the
reinforcement system and equipping some 206 Esate,RC of origin.
** Reinforcement of rear axles by means diferent:
[Image: 54600x450.jpg][Image: 55600x450.jpg][Image: 51600x450.jpg][Image: 53600x450.jpg][Image: 55600x450.jpg]
[Image: 51600x450.jpg][Image: 54600x450l.jpg][Image: 00211y.jpg][Image: 00310l.jpg][Image: 00611.jpg]
[Image: 00810x.jpg][Image: 906216img06261.jpg][Image: 20016932671.jpg][Image: 24198856651.jpg][Image: 24198877591.jpg]
[Image: 24198900211.jpg][Image: 24198926371.jpg][Image: 130420091445.jpg][Image: 130420091446.jpg][Image: ajoutdesupportpourrenfo.png]
[Image: croquita306homemade.jpg]
[Image: dscn0198jf3.jpg][Image: f386000kitb.jpg][Image: kitbaguesbronze20530930.jpg][Image: kitrefectiontrainar2051.jpg][Image: photo47y.jpg][Image: photo532.jpg][Image: pict1917t.jpg][Image: pict1919n.jpg][Image: pict1920r.jpg]
[Image: 96620100606143648016.jpg][Image: 019206rcfld.jpg][Image: mogf225g.jpg][Image: 54361145.jpg][Image: 98665765.jpg][Image: 54361145.jpg][Image: tarenforc306sur2051.jpg]
** Mounting PSA triangulated,reinforced rear axle :
[Image: p1100820y.jpg][Image: p1100821r.jpg][Image: p1110075w.jpg][Image: p1110076s.jpg][Image: p1110081q.jpg]
[Image: spec1e.jpg][Image: spec2b.jpg][Image: spec3y.jpg][Image: spec4.jpg][Image: spec5l.jpg]
[Image: spec6.jpg][Image: spec7.jpg][Image: spec8.jpg]
** Reinforced rear axles PSA riding a anti-roll bar 605 TD:
[Image: barredetorsionde605td.jpg][Image: barredetorsionde605td1.jpg]
** Adaptation rear axle 306-ZX-Xsara on 205-309:
[Image: installtrainarde306s16s.jpg][Image: ta306adaptetmontsur2051.jpg][Image: ta306adaptetmontsur2052.jpg][Image: ta306adaptetmontsur2053.jpg][Image: ta306adaptetmontsur2054.jpg]
[Image: ta306modifpour2053.jpg][Image: ta306modifpour2051.jpg]
** Technically I find it difficult to explain exactly how as thermal
techniques are complicated.
** This is often summarized as PSA with nice combinations montages
Plug & Play.
- Rockets, hubs, struts, torsion bars, rear turrets media,anti-roll bar
in the beam crosses media calipers,,, 3 out of 4 are Plug & Play from
one generation to another and from a range to another.
- 309,405 & Xsara are the main donor of organs and breaks,
company,estate,sport and preferably with ABS if possible.
The front and rear axles with ABS are often reinforced the Other standards
and sleepers yellow are the best from the point of technical.
- What is to remember is that the rocket arm and rear halves of 207 and 307
are used to mount to adjust the camber and toe rear.
- The document required :
[Image: 207mg.jpg]
** The rear axles PSA Homemade adjustable toe and camber :
[Image: 41109large.jpg][Image: 43600x450j.jpg][Image: 44600x450.jpg][Image: 45600x450.jpg][Image: 49600x450.jpg]
[Image: 50600x450.jpg][Image: 74238cf0f7e12bf48a628.jpg][Image: 956cdaaf.jpg]
[Image: 88fe8871.jpg][Image: 46600x450.jpg]
[Image: 47600x450.jpg][Image: 48600x450.jpg][Image: 49600x450.jpg][Image: 88fe8871.jpg][Image: 956cdaaf.jpg]
[Image: 74238cf0f7e12bf48a628.jpg][Image: carrossageavetarrsur205.jpg][Image: plancalestarglablepsa.png][Image: fuserglable32mm20530630.jpg][Image: fuserglable25mm306zxxsa.jpg]
[Image: photo13ug.jpg][Image: photo12am.jpg][Image: carrossagesurta205.jpg][Image: carrossageavetarrsur205.jpg][Image: p1060010e.jpg]
[Image: fusesen32mmrglables.jpg]
[Image: carrossageavetarrsur205.jpg][Image: fusee3.jpg][Image: fuserglablesurtapsa.jpg][Image: trainarrirerglable1.jpg]
[Image: trainarrirerglable2.jpg][Image: trainarrirerglable3.jpg]
** If you want to know a few prices a bit, here is a sample site French
selling these products.But there are more known, but even more expensive
time and quality level is often equivalent prices are only elastic lool:
http://www.jacques-point.fr/peugeot.htm
** Here are some other extremely useful:
[Image: unessieuarriredezx.jpg][Image: zxtra10.jpg][Image: brasar306suspensnormale.jpg][Image: eclattaxsara.jpg][Image: eclattrainarrirezx.jpg]
[Image: 207mg.jpg][Image: hauteurdelacaissemesure.jpg][Image: hauteursdegardeausolgam.jpg][Image: trainarriere.jpg][Image: trainavant.jpg]
[Image: 1484c.jpg][Image: coupetransversalelimite.jpg]
[Image: coupetransversaletraina.jpg][Image: eclatdemibrasarrta306zx.jpg][Image: eclatmoyeuarrpsa.jpg]
[Image: hb51a10a.jpg][Image: schmasfonctionnementtra.jpg][Image: semieclattrainarrbarres.jpg][Image: ta306suspensnormale.jpg]
** These plans a tool for the outer rings of axles PSA :
[Image: outilpourlabagueextrieu.jpg][Image: outilpourlabagueintrieu.jpg]
** 2-3 details on the rear axles:
[Image: butesdetrainarriere205p.jpg][Image: dsc00386uh3.jpg][Image: dsc00389cv2.jpg][Image: dsc00403wo3.jpg]
-_-_-_-_ I would hope that this will necessarily help you. _-_-_-_-
Thanks given by: crpt
Some fantastic content right there!
These write ups are amazing, tbf
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Hi guys, Mr Darrenjlobb in person ,,, ;-) It is a great pleasure for me.
Mr XUD reference, Mr over 200Hp, Mr M-TDi Twin Turbo Supercharged,Stoopp !! lool
However,it's with pleasure that I transmit these data.Still a mass of content available.
If you need something special, do not hesitate my friends ...
** Cheme wedge adjustment :
[Image: schmacalehomemaderglage.png][Image: rondelleconvexeconcavep.jpg]
[Image: 452340img1138.jpg][Image: 543629img1137.jpg][Image: ta306renforctriangulpou.jpg][Image: trainarrirede206.jpg][Image: trainarrierercousw2.jpg]
** An example of rear axle adjustable height and hardness.
Motorcycle shock absorbers mounted above, find the right size and fit dampers.
- For rolling and twisting arms behind backs, this is good.
[Image: photo164oc.jpg][Image: photo163cm.jpg]
  [How to] Assemble triangulated rear axle PSA fan2xud 0 2,809 05-02-2013, 03:37 PM
Last Post: fan2xud
