Making A Trip Computer Stalk
Guide: Making A Trip Computer Stalk
Right first off you'll need;
A wiper stalk in which to install the button.
A headlight stalk to take the button assembly and contacts out off
A dremel
Soldering iron
Wire
Pliers/Side cuts
Flathead screwdriver
Headlight stalk
Step 1
Diss-asemble the case, discard the top and bottom covers
[Image: 953879F3-ECB1-4388-A7BF-C790CF28C804-121...B1CFCA.jpg]
[Image: 2C760F93-5E1A-4559-9599-A7015AFE9F43-121...98DA2C.jpg]
Step2
Remove the contacts from the stalk, dont worry about damaging the pins they'll be removed later. Discard the casing they came from.
[Image: DC6475D5-9EAC-404D-B3A0-CFEEE3ED7A57-121...88AD4D.jpg]
[Image: B3DF9E82-DD70-46D3-9364-03B078E2CA65-121...8FFE04.jpg]
Step 3
Take the stalk part and remove the white cap from the bottom of the button movement, Ive found side cuts are best to do this with. Be careful not to bent the pin its connected to or damage the cap itself.
Remove the button and retain the spring and white cap.
Discard the stalk.
[Image: 94D8E02B-70C0-4411-AC6A-2A0B5F9ECEA7-121...8D1F25.jpg]
[Image: 8BDDAB69-0507-4078-919D-801A21E62767-121...791428.jpg]
You now have all that you require from the headlight stalk.
Wiper stalk
Step 1
Remove the top cover from the stalk
[Image: 74152E4A-9E9A-42B9-9DCC-50E8A1C8098D-121...757DFB.jpg]
[Image: 41805717-C29B-467D-A8B4-B75A02EAB70C-121...F1C98D.jpg]
Step 2
remove the twisty part of the stalk by removing the metal column that it clips into.
A smallish flat head screw driver works best for this. the headlight stalk has the same part so may be worth practicing on that first?
[Image: 324C01F4-05F6-4401-97C4-B83E7ACC7187-121...1ED33B.jpg]
[Image: DF2B3A98-FC0E-4624-BAE3-1575EDCC2676-121...C1B0E5.jpg]
Step 3
Remove the fake button, this is a push fit into the top of the stalk, This is the most difficult part to do without damaging the casing.
I found using something around the same size as the button rod to push the button out worked best but it is well secured.
[Image: D78F5EDA-47A4-40FD-AA14-3285DD11EE45-121...C77408.jpg]
Step 4
Reasemble the stalk top onto the metal inner part and insert the button and spring, and push the white cap back onto the end.
[Image: 22F91C8B-CE2A-47EF-B40E-03FBD8195669-121...C93AC7.jpg]
[Image: D56A2ADF-03EA-4CF2-BE5F-677A2D8A1B85-121...29148F.jpg]
Step 5
Take the bigger contact and cut off the pin part.
You'll also need to shorten the part that fits in to the stalk itself, but not by too much as it wont be a snug fit
sidecuts should do just fine
Fit this into the housing temporally
[Image: F4C97856-4013-4614-A76A-3F4C8D35688D-121...62BC64.jpg]
[Image: 620E3183-E774-4D06-8A58-2ACBA2BA7F81-121...28D5E7.jpg]
[Image: 31374C3C-936A-48ED-9F46-EACE90550D18-121...20B79E.jpg]
Step 6
Remove the metal from the smaller pin thats colouered in blue.
A dremel with a cutting disc is what I've been using.
You'll most likely need to reshape the contact too and remove some more metal too (again blue) untill it sits in its slot properly and the contacts meet nicely.
[Image: DFC10781-1D47-4C74-B59F-8DA67B2D951E-121...F8F77F.jpg]
[Image: 774857EB-1437-4F2E-ACBB-0C2C72C8D835-121...6545AB.jpg]
[Image: 5F9BC8E9-B195-45DE-9342-93E3C3DE2115-121...6C736D.jpg]
[Image: E3C23B08-F68E-444D-9027-8D698FFBF235-121...64EE40.jpg]
Step 7
Remove both contacts and solder a wire to each
Drill a hole in the side of the casing to feed the wires through and refit the contacts.
The smaller ones is likely to need to be glued in, I used sure glue just fine.
Check the contacts and adjust as necessary.
Step 8
refit the stalk and top cover and you'll be done!
The hosing on the car for the stalk will need modifying to clear the wiring but nothing major.
DISCLAMER: This is done at your own risk and this just shows how I have carried out this modification.
You can also use a xsara wiper stalk that has a button for rear window heating at this place and fits p&p into the 306 Wink
Step 7
[Image: C893DB9B-2BCA-4F5C-A873-EE43F18DFA40-121...2B9C27.jpg]
[Image: 9FD53ABB-4C02-4F48-AE3F-38D9A353E026-121...5C494E.jpg]
Step 8
[Image: 187D539C-C3AD-4672-A3A2-87AA0CDD7E17-121...FE19AE.jpg]
(27-01-2013, 01:27 PM)306Cabrio Wrote: You can also use a xsara wiper stalk that has a button for rear window heating at this place and fits p&p into the 306 Wink
That is the case, but its the same style stalk as fitted to the 406 and IMO the 306 ones look nicer.
[Image: sig.jpg]
Good man cheers for doing this! WIll have a go tomorrow night seeing as hopefully my TC will be here tomorrow Big Grin
Hopefully it does, as all I'm waiting on is the ecu part and confirm that it works then mine will be in the car.
[Image: sig.jpg]
Chris, your fitting it into the gti right? Ill pm you. Would rather not put out the details on here until i know they are right.
Edit: Just done this with some spare stalks. Took about 15 minutes and was fairly easy to do. One point to make though. Knocking the fake button out can be a right pita without damaging the stalk. I found it easier using a good quality set of pliers to just pull the button out.
Awesome stuff. This will keep everything looking nice and OEM.
  Trip Computer Guide (HDI) DeeTurbo 124 100,858 29-10-2017, 12:37 PM
Last Post: Lukas
  Guide: Making a fly off handbrake Jonny81191 21 9,807 26-06-2013, 10:01 AM
