Ph2 and 3 Wiring Diagrams
Most of the wiring diagrams as well as fuse locations and general component locations.
All engine diagrams are for the GTi engine but i can add others if needed.
Enjoy Smile
.pdf   2000 306 ECU XU10J4RS.pdf (Size: 356.98 KB / Downloads: 1,007)
.pdf   2000 306 XU10J4RS instrument panel.pdf (Size: 642 KB / Downloads: 774)
.pdf   306 Earth Point Locations.pdf (Size: 108.13 KB / Downloads: 896)
.pdf   306 GTi6 Torque Settings.pdf (Size: 88.57 KB / Downloads: 568)
.pdf   306 Service Indicator Reset.pdf (Size: 81.11 KB / Downloads: 492)
.pdf   2000 306 ABS System.pdf (Size: 214.91 KB / Downloads: 545)
.pdf   2000 306 Airbag System.pdf (Size: 17.07 KB / Downloads: 478)
.pdf   2000 306 Automatic Temperature Control.pdf (Size: 335.59 KB / Downloads: 582)
.pdf   2000 306 Central Locking with Deadlocks.pdf (Size: 270.61 KB / Downloads: 634)
.pdf   2000 306 Charging System.pdf (Size: 154.15 KB / Downloads: 526)
And more....
.pdf   2000 306 Cooling Fans.pdf (Size: 321.27 KB / Downloads: 594)
.pdf   2000 306 Dash Fuse Locations.pdf (Size: 61.47 KB / Downloads: 584)
.pdf   2000 306 DLC Wiring.pdf (Size: 175.05 KB / Downloads: 534)
.pdf   2000 306 Electric Windows One Touch.pdf (Size: 168.49 KB / Downloads: 569)
.pdf   2000 306 Electric Wing Mirrors.pdf (Size: 198.23 KB / Downloads: 485)
.pdf   2000 306 Engine Bay Fuse Locations Maxi Fuses.pdf (Size: 25.31 KB / Downloads: 529)
.pdf   2000 306 Engine Bay Fuse Locations.pdf (Size: 36.02 KB / Downloads: 521)
.pdf   2000 306 External Lighting.pdf (Size: 22.39 KB / Downloads: 557)
.pdf   2000 306 General Component Locations.pdf (Size: 75.47 KB / Downloads: 562)
.pdf   2000 306 Magneti Marelli IAW 1AP.10 Pin Data.pdf (Size: 495.8 KB / Downloads: 629)
.pdf   2000 306 Power Distribution.pdf (Size: 564.52 KB / Downloads: 573)
.pdf   2000 306 Relay Locations.pdf (Size: 32.49 KB / Downloads: 567)
.pdf   2000 306 Wipers With Rain Sensor.pdf (Size: 258.87 KB / Downloads: 526)
winning! Can we had HDI ones please Big Grin
Yep will do once ive had lunch.
.pdf   2000 306 Interior Illumination.pdf (Size: 194.35 KB / Downloads: 544)
*cough*
Tradesman's "lunch", standard.
Any chance of the phase 3 audio wiring diagram as the one in the haynes manual seems to be wrong.
Where would I find window system diagrams for x reg 1.6 petrol meridian? These are for gti6 but appear to be a bit different although similar.
I also wondered if there are wiring diagrams for the different switches , there are a few different part numbers for these switches so they must be different! Not sure the one in my driver side door is original correct switch, hence what looks like a rewording of the plug! Need to know the original, and what it's wiring is to work it out lol!
Thanks
(20-01-2013, 01:46 PM)Eeyore Wrote: winning! Can we had HDI ones please Big Grin
You finished lunch yet, Niall?
He put the HDI ones in a separate thread.
http://306oc.co.uk/forum/showthread.php?tid=10000
Ahah cheers, missed that!
(20-01-2013, 12:15 PM)Niall Wrote: Most of the wiring diagrams as well as fuse locations and general component locations.
Enjoy Smile
Thanks bro ^_^ :-)
  HDi Wiring Diagrams Niall 1 5,683 20-01-2013, 02:34 PM
