Heater matrix? How hard to change?
Hi guys just changed the radiator on the ph1 and noticed water in the passenger footwell. Can see were the water has come down from the centre lower heaters and it's wet inside the vents. Could it be the matrix or water from the rain getting in some were.
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Sounds like the heater matrix is leaking to me but you could check your expansion tank and start the engine with the cap off, see if more water appears inside the car.
It could also be you aerial or sunroof leaking.
Deffo matrix there's a puddle in the foot well. Can see it coming through and it smells like solder ;(. Anyone fancy doing a matrix?
Ph3 perv cab heaven
Black ph1 XUD died
ive got to do mine next weekend Sad
Done mine Smile
Ph3 perv cab heaven
Black ph1 XUD died
  heater matrix flush Ben_w 3 3,447 02-08-2016, 03:48 PM
Last Post: DeeTurbo
  heater matrix swap jayspug86 32 18,023 06-01-2015, 06:06 PM
Last Post: jayspug86
  Heater matrix DeeTurbo 10 6,100 06-06-2014, 08:09 AM
Last Post: londondan86
