Londondan's Black Supercharged XUD New Video Inside!! :D
FYI, the head. Don't bother with an uprated cam... Not very good bang for buck.
Get it gas flowed, bigger valves, with 5 angle seats and you'll be about where you need to be. Just DO NOT use Hiflowheads.
JP
JP
(15-12-2013, 12:18 AM)Frosty Wrote: Looking good chap! How far is it off running again?
Hopefully the engine will be running again tomorrow. I need to get a thermostat and I need to collect my new header tank from the post office (bloody postman came at 5pm yesterday) also waiting for my brother in law to bring me back the hubs as they're getting bearing pressed in.
(15-12-2013, 08:57 AM)Chris_90 Wrote:
(15-12-2013, 08:43 AM)Niall Wrote:
(15-12-2013, 07:57 AM)Chris_90 Wrote: What's the benefit of the bigger crank pulley? Looking good Big Grin
Increases the charger speed so more air being pushed through. IIRC Darren had that pulley made to take the charger up to about 15,000rpm which is about their limit. Pretty sure it was 15k anyway!
Oh interesting Big Grin more boost is defo for the win Wink
Spot on Nial! Big Grin and yea, more boost is always win!!!
(15-12-2013, 09:22 AM)jammapic Wrote: FYI, the head. Don't bother with an uprated cam... Not very good bang for buck.
JP
Yea the cam came with the spare engine so no cost outlay. Going to have a word with the machine shop to see what can be done on the head, all depends on the gains as they do flow really well standard. I wont spend 600 quid for a 3hp gain just so I can say "gas flowed becauseracecar" lol
Why not use Hiflowheads? The reviews online look pretty good from what I can tell (I'm not using them, just curious)
HDi Cabby Project Click
DONT TOUCH HIFLOWHEADS
That said back on topic.
Good work! Great to see the win setup back together, and its looking much tidier this time, love it Smile
For those who asked, the pulley is to gear the charger up, otherwise it was only running at just under half speed, so i had that made to gear it so that at 5000rpm it was just touching eatons "max rated speed" I used to rev it out to 6200 so just over that, but they seem to be fine, but yeah was just to get more boost!
Darren did you ever have any issues with that like belt slipping or heat issues? Considering a -19% pulley for mine as long as it doesn't cause too many issues!
The charger pulley you mean? surely you dont want to make the crank pulley smaller... id say you will need to gear it up still not down..your only revving to what 7200rpm or so?
Never had trouble with belt slipping on the charger, only on the alternator once when i didnt have enough contact, but fine after i added an idler
Nah I'll be keeping the crank pulley standard size but fit a smaller charger pulley. I haven't worked out the speeds yet so I'm not even sure what it will rev the charger to now but if I can get it up to about 15k at 7500rpm, I'll be sorted Smile
Ah, i was going to do that but realsied A i couldnt small enough to make it fast enough, and b the pulley was seized to the shaft like a sodddd
Yea I've never had problems slipping on the charger as there's so much belt contact around it although the alternator did slip quite a bit without a lot of tension.
Meh. Who needs an alternator when you have a supercharger :p
Looking great!
Think you win the award for the most hectic block.
Wanted to come help when this went back together, did my invite get lost in the post?
(15-12-2013, 06:02 PM)Niall Wrote: Meh. Who needs an alternator when you have a supercharger :p
Lol, is there a law against candle headlights!!
(15-12-2013, 06:32 PM)c.gerrard Wrote: Looking great!
I'm hoping to tidy it all up once it's going, no idea yet how Darren got his looking so tidy lol! And don't forget this is only build 2 of 3 so you can defo come up on the next one matey! This has been a bit build a bit when I have time at the moment!
Hiflowheads took £2711.17 of my money and never delivered me anything...
JP
Can't wait to see this back up and running. When will it be back on the road. I'll be sure to look out for it.
NO SMOKE NO POKEBig Grin
It lives! Done 11hrs on that car today but pleased with progress. Anyway video first!!!!
No exhaust from the downpipe back in that vid so its a bit loud. Also she's leaking derv from the fuel filter housing as the seal had dried up and I didn't have a spare.
I still need some sort of hydraulic hose for the power steering pump -> Resevoir
Below is my header tank, just taken it to my brother in laws work where hes on nights so it can be modified for the ~12mm hose which goes to the water pump.
These b*stards were a nightmare today, took about 20 mins for each injector to get out. As you can see I ended up using a screwdriver to split them in 2 to get them to move!!!
After the injector seals were done I began making progress
Intercooler and rad on
Front end on, hopefully I dont have any water leaks now!! :S
New number plate on Big Grin
Not had the hubs back yet so she cant go anywhere yet Sad
Also the bloody rev counter still doesn't work Huh I'm thinking that Ben who had the car last has put hdi clocks in so I may require some late P2 clocks with the light up needles and approx 130k.
Amazing progress! Well done
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
(16-12-2013, 10:31 PM)Anton Wrote: Amazing progress! Well done
Cheers matey, nothing like hearing a car cough and spit into life after it's been in bits!
Also the throttle cable routing is causing it to stick, may need to look at getting a shorter one.....
just brilliant mate, well done.
Looks fantastic mate. I want a trip out in this next time i see you!
I had to use Ph2 xud clocks in my ph3 to get rev counter to work...if that helps!?
Well done with this mate Smile
Can't wait to see this up and running!
JP
great stuff . . . .loving the work, looks like you're doing a good job with it . .Smile
nice work man. sort of motivating me to go finish my own now haha
Good work on getting it all shoved back together, won't be long till its on the road Smile
Cheers guys^ Just got back from picking up my hubs so as long as she holds her water she'll be getting driven out tomorrow!
Xuds are supposed to hold water? What?
(22-12-2013, 11:37 PM)Tom Wrote: Xuds are supposed to hold water? What?
lol, yea made me chuckle as I wrote it. Its more of a Christmas wish than anything else lol
(16-12-2013, 10:27 PM)londondan86 Wrote: It lives! Done 11hrs on that car today but pleased with progress. Anyway video first!!!!
Those clocks are out of a Ph2 Dturbo and they worked fine in the old car!
Car history (starting Jan 2012):
106 1.1 Zest2 (Scrapped)
206 1.1 (Sold)
306 Dturbo (Totaled)
BMW 318i E46 (Sold)
306 Dturbo (Engine failure)
306 HDi Estate (Sold)
306 Dturbo in black (Sold)
205 1.9 GTI (Sold)
Golf GT TDI
Really odd, I've tried all sorts with them, I've just bought another set on here so I'll see how I get on in the new year.
No progress due to rain coming in sideways yesterday so nothing to update at the mo. Sad
just out of interest what turbo and supercharger is it/are they, iv spent 3 and a half hours on lobbs threads lookin for insperation on a supercharged/turbocharged xud, also without trying to hijack your threads (sorry in advance if i do lol) but have you thought about the 6 speed box from a gti6, wernt to sure how itd suite the xud if it were possible swap that is. loving the work though mate, i cant stop reading through and looking at the pictures with excitment haha
I don't know what the turbo is on this setup, but I expect the supercharger is an Eaton m45...
JP
  Londondan's HDi Cabby Project londondan86 11 7,287 07-06-2016, 12:09 PM
Last Post: insomaniac45
  Carlos182's Bora Project (Exhaust Video inside) Carlos182 122 41,058 26-02-2013, 06:57 PM
Last Post: Carlos182
  Londondan's Smoothed Stage 2 HDi Estate 152bhp RR Vid inside! londondan86 50 29,283 23-02-2013, 05:05 PM
Last Post: RJDubya
