seized coilovers 306 hdi
I have a set of coilovers on my 306 ph2 and the driverside has seized ,
I've spray releasing spray on it and had a bar on it but its still stuck,
Any over ideas to free it up?
Ph2 HDI? Hmm
Also what part has seized? The adjusters? It doesn't really make much sence.
Stage 2 XUD Sedan
Yes sorry the adjusters have seized, I can move the lock ring, that still moves .the one closest spring for adjusting the height is. stuck soild
just gotta keep trying with the spray i guess. Not sure if you could try and wack it and shock it into moving? Or wether you could heat it up?
Hadn't thought of giving it a whack ,may try it if it stops raining 1day
I did mine today... Loads of spray, cleaned threads with wire brush. One was a little seized to FO Big screwgy and a hammer... Voilah! ;-)
[Image: Sig3_zpscd005eb1.jpg]
Yeah, as above. Some penetration spray, then a tap/bash (select appropriately) with your implement of choice. Then go over all the threads with either copper crease or chain lube etc Smile
  Union on rear brake cylinder seized.. laurence_13 4 3,685 18-04-2014, 02:28 AM
Last Post: bashbarnard
  rear brake seized?? readie 5 3,411 01-06-2013, 01:49 PM
Last Post: MartinL
  GTI Caliper Issue - Seized 'Slider/Damper' ??? ginge191 12 7,348 12-12-2012, 07:38 PM
Last Post: ginge191
