GTI Caliper Issue - Seized 'Slider/Damper' ???
Pics describe this better than words..
Basically, taking the carriers apart, on each carrier there is 2 damper type springs on each side...
on each carrier i have one seized
The boot to protect it from seizing has obviously failed at some point and rusted the inners - the insides are greased which acts as the damping for these little widgets.
Anyway, anywhere i can new ones from? Besides the scrapyard as we have NO Gti's in our scrappies, OR is there i way to get these out - got some WD40 soaking at the moment and a lot of MTFU on it..
Heres some pics.
GOOD! Big Grin
[Image: W4z1h.jpg]
BAD 1 Sad
[Image: IJNV1.jpg]
BAD 2 Sad
[Image: Ovo7B.jpg]
EDIT: ALSO saw Johnny re-build his calipers last year, read it on .net, maybe he could have some input if he's around, rather than his usual spam..
Need a new slider kit, cheapest I could find was £27 each caliper. I've just done mine
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Anton Wrote:Need a new slider kit, cheapest I could find was £27 each caliper. I've just done mine
got a link for that mate at all??
Mate i didnt realise they were like that Confusedad: anything i can help with?
Current cars
Subaru Impreza 2.0d - Daily
http://www.biggred.co.uk/index.php
http://www.brakepartssuperstore.org.uk/ ... d9626.html
It's a pita job, good luck
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Oi i dont just spam ill have you know ha ha!! You don't have to buy new ones just stick em in some coca cola for a day or so!!! No joke then wire Brush em, wet and dry em, good to go, clean out the Channel they sit in get a pipe cleaner in there and recoat with red rubber grease, jobs a good in
[Image: SDC10442-1.jpg]
Also if they don't need a new seal set then don't it's a fecker getting to pistons back in with new seal as well as getting the rubber in its recess
Ok, update, Dan, it's cool mate, i'll see how much the new bolts cost... will keep you in the loop Smile
So, i managed to get both out, the 2nd was an absoloute PITA - ended up BENDING the bolt, mental - got a drill and wire brush adapter and blitz'd them for couple of hours, hands are killing but they look clean and fresh now, gave them a lick of black hammerite and they should be fine.
As for the main piston, would you be able to test them with your hands? i can compress them and it squirts everywhere, good enough?
Anton, i found them on ebay and sent them a message for the specific part, i'm not sure what im looking for/size/spec etc.
Ginge bring them along to Ace tomorrow and ill have a look, I fear that even though you have "smoothed" it back, that the hole will be slightly bigger than the sliding pin
Will bring you some proper caliper grease as well on Monday,, Iam sure they can be saved
Yeh, i'll bring them tomroow..
Where can i find the code for the caliper - i've found the slider pins, but unsure on caiper code - can't find it on the caliper?
measured the pin and its 70mm in length, 10mm width, but they offer 5 different pins...
Ok, for those of you that maybe interested - been in contact with BiggRed http://www.biggred.co.uk/, and posted my bolt to them
He (Tony) has found the correct bolt, an Astra bolt http://www.ebay.co.uk/itm/270955072452?r...3D1&_rdc=1 which fits and is the same measurements.
Just paying for 4 new ones, great help indeed - be aware, the bolts do not include rubber seals/boots so will need to pay for them seperately
  Power Sterering Ram/ Steering damper pugfrank 6 6,878 08-11-2019, 01:47 PM
Last Post: pugfrank
  Front caliper refurb - stuck slider pins 306rhys 11 5,623 12-07-2015, 02:36 AM
Last Post: HDi--Power
  rear disk slider bolts tigerstyle 7 3,805 16-06-2015, 04:45 PM
Last Post: Stef205
