Union on rear brake cylinder seized..
Just gone to replace my brake cylinder as it was leaking, went to undo the union nut that according to the guide is 11/13mm... 11's slightly too big and grips but not enough to undo it and 10s far too small.
Thought about undoing the pipe where it joins the flexi bit of hose and threading it through but that's stuck solid too...
Any ideas?
Cheers laurence
Use a proper brake pipe spanner or it will round
Failing that mole grips
Or chop the union off and flare a new one on
Team Doesn't own a 306
(17-04-2014, 08:26 PM)Danny2009 Wrote: Use a proper brake pipe spanner or it will round
Hmm theyre already slightly rounded, ill see if i can pick up one of those spanners tomorrow
Proper spanner and plus gas. This did mine Wink
If not cut the pipe flush to nut. Hammer on socket. Make new brake pipe up. It's only a shirt one. Clamp the flexi hose off first though. If you.dont have a proper tool to clamp it use a pair of mole grips with a bit of cardboard
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,264 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 4,036 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 6,019 24-04-2018, 07:11 PM
Last Post: Ben
