5mm Spacer Advice
5mm Spacer Advice
Hi guys,
Hate the sight of the white oregons on the front of my car. Fondmetals wouldnt fit as they were catching on the calipers and I cant grind down any more of the caliper.
I am thinking 5mm spacers on the front to definitely clear them and once the pads have worn down then Ill take the spacers out again.
On ebay i see:
universal 4x108 spacers with 71mm CB for £6.
specific 4x108 spacers with 65.1 CB for £40.
Planning on getting the cheaper ones as I am not planning on running them for long. Main question is with 5mm spacers will i need longer bolts?
Thanks
Sam
It is advisable as your taking 5mm thread out of the hub essentially but I would of thought it would be fine it's all down to you really
Personally If the bolt screwed in a few full turns I wouldn't bother
Team Doesn't own a 306
Yes you will need longer bolts. Do they take tapered? If so i have a set here brand new which may be good for you. I bought the, for my winis but were too long for me. Might suit you.
Also, the cheap ones have a bigger CB. I would imagine you want it to be correct as if you don't get it right, you might have a horrid wobble.
As said, don't do this without longer bolts. It really isn't worth the risks!
5mm is fine, I ran ouragans on my old 1.6 with 5mm spacers and standard bolts for well over a year! I still got at least 7 turns iirc
Fuxk taking wheel bolt advice from you Matt! Your wheels are always falling off!! May I remind you of FCS a couple of years ago? Wink
Niall I may come and grab them off you. Yeh outs the tapered ones I need for the fondmetals!
Fuuuuuu man, I'd had them fitted by a mechanic as I was unsure of fitment
The most thread you will ever need is half the diameter times pitch of the thread. Any more is there for the shits and giggles. So say m12x1.25 is 6 x 1.25 is 7.25 threads. You should be fine
Ordered some. Thanks for your advice everyone! Big Grin
(12-05-2014, 07:54 AM)pugmanxud Wrote: The most thread you will ever need is half the diameter times pitch of the thread. Any more is there for the shits and giggles. So say m12x1.25 is 6 x 1.25 is 7.25 threads. You should be fine
7.5
I run 20mm's on the Datsun becauseracecar.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
I ran 5mm spacers with standard bolts for ages on my sedan (because the beam was shagged) and they were absolutely fine, plenty of turns on the bolts before they got tight Wink
The Audi has been running 5mm spacers to clear the coilovers on the front for around 4 years. Can still get 7 turns with standard bolts, I'm happy with that. Just cheap universal spacers too, I just make sure they're centred by eye.
Went and saw Niall tonight and got some long bolts from Him. Better safe than sorry especially on track!
I posted this exact question on the other forum earlier, but for road wheels, and 3mm spacers.
Will I need longer bolts? If so, where can I get them from?
Thanks in advance Smile
Chris
1999 China GTi6 Supercharged track car
2000 Bianca LX non turbo slowness
Team: I hate Sam Rowell's stanceboard!
App what's needed for 306 m12x1.5 or m12x1.25?
(14-05-2014, 12:49 PM)kentiiboii Wrote: App what's needed for 306 m12x1.5 or m12x1.25?
m12x1.25 according to what i see on ebay.
(14-05-2014, 12:41 PM)cjm_harris Wrote: I posted this exact question on the other forum earlier, but for road wheels, and 3mm spacers.
I wouldn't worry, you don't need them for 5mm so Definatley won't for 3mm
  3mm spacer need longer bolts ? carlukepeugeot 0 993 22-04-2018, 01:10 PM
Last Post: carlukepeugeot
  another SPACER/BOLT questions thread...HELP asap Piggy 6 1,633 23-04-2014, 02:12 PM
Last Post: Piggy
  wheel spacer questions Piggy 10 2,110 17-04-2014, 08:06 PM
Last Post: kentiiboii
