another SPACER/BOLT questions thread...HELP asap
ok, sorted me some spacers...wider than initially had in mind, but I have the arch gap, so be fine....
anyone, one pair is normal hubcentric with longer bolts...sorted, fine.
the other pair, wingnutz has informed me, are the bolt on type like these...
[Image: !BzvQMwwCWk~%24(KGrHqJ,!joEw5JYckHjBM(Y1FNI5g~~_1.JPG]
fine I though....but he has no bolts... doh Doh
so two questions:
1) anyone got a set of 8 of the special shallow headed bolts to bolt these to the hub
2) could a set of short tapered steel bolts be used if I cut the heads down to be shallow headed??
thanks!!!!
need it sorting asap
Might be worth pm'ing frosty i know he had this type and had to source one or two for spares
[Image: av5ym8.jpg]
I would talk to some of the eBay sellers and see if they would sell the bolts individually to you? I wouldn't want to mess about cutting anything down bud.
I would also check what the back of your alloy would look like. You could use bolts where the heads protrude from the face of the spacer if you were running Cyclones, since the would be no material pressed up against the spacer (it would sit in one of the gaps between the bolt-holes if that makes sense).
What does the mating face of your new alloy look like?
[Image: Sig500x130.png]
I had to buy 1 but it cost be like £4/5 I think so if you need 8 be nearly cheaper to buy the spacers and bolts together.
Maybe worth calling speedshacks I've heard be go on about them
http://www.speedshack.co.uk
Don't see why you couldn't cut the heads down on some normal bolts tbh, as long as you can still get a socket on enough to do them up and get them off, and the taper matches up with the taper in the spacer, don't see how it'll affect the tensile strength
Might take you a while though to do 8 with a hacksaw ...
Get the angle grinder out and trim some down. Take no time.
speedshack want £1.50+vat each plus £8 postage
Im guna trim some down...but fyi, you can buy them on ebay individually....
http://www.ebay.co.uk/itm/M12-x-1-25-22m...20ce59df92
(thanks for input guys Smile )
  3mm spacer need longer bolts ? carlukepeugeot 0 2,056 22-04-2018, 01:10 PM
Last Post: carlukepeugeot
  5mm Spacer Advice Eeyore 18 11,100 14-05-2014, 02:25 PM
Last Post: Matt
  Bolt Thread Scouse282 3 2,877 06-05-2014, 05:41 PM
Last Post: Piggy
