wheel spacer questions
So if I use 10mm spacers, its considered that I need hubcentrics.
Annoyingly expensive and a pair I have bought have been lost.
But with proper OEM shouldered/flat seated extended wheel bolts, are hubcentrics still needed? As I have a brand new set of 10mm spacers, non hubcentric. Undecided
May seem a noob question to some...but I have never fiddled with spacers before on wheels, other than full bolt on hub conversions
The issue is the loading ending up being on the bolts rather than the hub
That being said, I'm going to go all out and say its unlikely your wheel will fall off if you don't use hubcentrics
So either crack on, or stop being a tight arse if you're concerned about safety
Hubcentrics would be wise on any form of spacer IMO. The 'lip' on the hub currently helps to centre the wheel but also takes the most of the load. I know this always encourages argument from some parties, arguing that the friction between hub face / spacer / wheel takes the load when the wheel bolts are tightened, but I don't subscribe to that. For starters on something like a Cyclone wheel the female coupling 'ring' if you will is incomplete; with only material at the bolt-holes. If that makes sense (it does in my head!)
Hubcentric or nuthin' IMO.
[Image: Sig500x130.png]
Fair enough. Its just a set of hubcentrics is £65. Plus bolts comes to £95.
Thats a lot for alloys that I got for nothing!!
What about plastic spigot rings, they can't take any load surely? So hubcentrics being needed....?
The spigot rings sit on top of the shoulder so will still transfer the weight onto it. Theyre just taking up the few mm gap.
As above basically, if you have to use a spigot ring it will be to take up slack and be made of rigid plastic - not a maleable rubbery material. Plus, it should be a nice snug fit, so the plastic has nowhere to go but take up any load from hub / road wheel.
The spacers on my OZ wheels were £130 shipped from Italy brand new and were direct fitment, so £65 sounds about the going rate.
Shop around for wheel bolts and you may get a bargain. Just don't take a chance on something like spacers if you can avoid it.
I've used 10mm spacers non hubcentric before
Never had a issue
20mm however I used hubcentric
Team Doesn't own a 306
(17-04-2014, 02:34 PM)Piggy Wrote: Fair enough. Its just a set of hubcentrics is £65. Plus bolts comes to £95.
Thats stupid! I paid £35 for brandnew 15mm hubcentrics.
http://pages.ebay.com/link/?nav=item.vie...1046917689
No, thats £10 cheaper than what you paid...
A set, IE 4, coz I use 4 wheels on my 306! Tongue
(17-04-2014, 08:03 PM)Piggy Wrote: No, thats £10 cheaper than what you paid...
Oh set of 4, thought you meant pair. :-p
£65 for 4 is good imo!
  3mm spacer need longer bolts ? carlukepeugeot 0 1,959 22-04-2018, 01:10 PM
Last Post: carlukepeugeot
  5mm Spacer Advice Eeyore 18 10,522 14-05-2014, 02:25 PM
Last Post: Matt
  another SPACER/BOLT questions thread...HELP asap Piggy 6 3,950 23-04-2014, 02:12 PM
Last Post: Piggy
