3mm spacer need longer bolts ?
Hi folks
Was thinking of putting 3mm spacers on the back to just give  a smidge more clearance between the back of the tyre and the wheelarch liner. Axle is still pretty good, not much camber but I just went from 14"  harriers to 15" cyclones on 195's and there's not much room there, especially as I fitted a phase 3 liner on the nearside (it's a  phase 2 car which didn't come with one on that side) - the liner fits well but bulges a little.
Just wondered if I am likely to need longer bolts with just a 3mm on there?  Bolts are all new and are as below. I'll check their protrusion through the wheel. Rule of thumb 1.5 x diameter ?
[Image: s-l1600.jpg]
  Part no longer available? Mighty306 10 6,149 11-04-2017, 08:51 PM
Last Post: Stef205
  5mm Spacer Advice Eeyore 18 11,100 14-05-2014, 02:25 PM
Last Post: Matt
  another SPACER/BOLT questions thread...HELP asap Piggy 6 4,140 23-04-2014, 02:12 PM
Last Post: Piggy
