Handbrake light comes on while driving
Hi all,
Sorry for the multiple questions lately but there's some niggles I need to work out Smile
Driving my HDi home after buying and after 10-15 minutes or so the handbrake light came on. Pulling the handbrake makes the light slightly brighter.
I've checked the brake fluid and it's up to the mark no problem.
I've been told it could be brake wear sensors, is that possible?
If not, what else could it be?
Thanks all,
Andy
Its the low fluid level sensor, but seeing as you've topped it up, its probably down to dicky wiring somewhere, maybe a connection. The pad sensor is an orange light on the dash afaik, so its not that
Thanks Connor. It didn't need topping up as it was all OK and looks brand new as it was fairly clear pale yellow fluid. It's probably a bad sensor as you say but I will keep an eye on it. Cheers.
Check the switch under the handbrake as well Smile
HDi Cabby Project Click
  Handbrake Light while driving MY95 23 11,838 12-05-2016, 07:14 PM
Last Post: DeeTurbo
  how many things does handbrake light represent? dr_jekyll 7 5,023 02-04-2015, 09:42 PM
Last Post: Vpricey
  Abs light & handbrake light. mcglynn 4 4,057 17-12-2014, 11:01 PM
Last Post: mcglynn
