how many things does handbrake light represent?
How many things does the handbrake light represent? Mines stuck on and didnt know if its just a simple faulty sensor or chaffed wire
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Is it just the handbrake light on? If it comes on with stop light itll be low fluid warning, if its on its own itll most prob be the little switch under the console
Sweet thats all I thought it was, just plays my turbo timer up as the cut off is wired into the handbrake for safety
Justin_306DTurbo
Could be brake fluid low!
Na brake fluids sweet. Must be the sensor as what other reason would my turbo timer play up for? It's t'ed into the handbrake sensor wire
Justin_306DTurbo
Hi guys, I have the same problem, what and where is the switch under the console?? My brake fluid is topped up and it gets a bit duller when the handbrake goes off.
Any ideas?
Thanks Paul.
Under the handbrake itself ThumbsUp
Ok I'll check, ta. Smile
  Handbrake Light while driving MY95 23 12,178 12-05-2016, 07:14 PM
Last Post: DeeTurbo
  Abs light & handbrake light. mcglynn 4 4,134 17-12-2014, 11:01 PM
Last Post: mcglynn
  handbrake/low fluid light on dash gavxud 2 2,913 15-02-2014, 11:50 AM
Last Post: gavxud
