Threads: 591
54
(08-12-2014, 10:31 AM)Paul_13 Wrote: Could you leaking oil from somewhere and it's contaminated the fly wheel? Crank seal letting by?
Oil breather system pressurising?
Go wash your mouth out!!!
Threads: 42
28
ML box and stock 2.1 or a DW12 flywheel?
Threads: 541
124
08-12-2014, 12:30 PM
(This post was last modified: 08-12-2014, 12:31 PM by Dum-Dum.)
I have a DW12 flywheel if it helps although the clutch is ruined.
The helix cover probably has a fair bit more clamping force
Threads: 591
54
XUD11 flywheel is heavier but not bigger.
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
in gear boost (torque) control with the arudino.
Just another sensor and a little programming.
Threads: 136
11
I won't make suggestions to try and help then.
I've had that issue in the past which is why I said it
Threads: 21
3
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
(08-12-2014, 07:53 AM)Piggy Wrote: (08-12-2014, 12:16 AM)HDi--Power Wrote: (07-12-2014, 09:37 PM)Piggy Wrote: Yeah. Full CG stg3 kit. Been sent to CG and refurbed just before fitting too.
The CG pressure plate is just a standard Valeo with 3 grooves machined into it. It has no higher clamping pressure than oem, all the extra torque holding ability comes from the center plate, so you could in theory just buy a helix uprated pressure plate and hold mega torque.
Really!?!? This true!? Geeeeeeee
Guess that would be the weak point then!! Its not a weak point per say, as its plenty good for what they rate it to, but it is your weak point with this setup. Given the extra friction of the cerametallic pucks i dont think you will need something with a massively higher clamping force to hold it.
Threads: 591
54
(08-12-2014, 12:50 PM)nominous Wrote: in gear boost (torque) control with the arudino.
Already have this in place.
But kind of defeats the whole idea.
May aswell have a slower spooling turbo!
Threads: 91
83
No point in in gear torque control... The Arduino isn't controlling injection quantity, only boost control, you'd have a better effect just not putting your foot down... It'd just smoke like a twat when it's limiting boost...
Though clutches slip in high gears when you need the torque...
Threads: 42
28
(08-12-2014, 12:36 PM)Piggy Wrote: XUD11 flywheel is heavier but not bigger.
is 235mm not bigger than 215?
Threads: 541
124
The 406 2.2 HDi clutch (for which i have a dead one and a flywheel) is 240mm
Threads: 41
3
The LDA is driven by the boost.
So if you limit the boost you should be limiting the fuel.
Boost thus being limited by TPS reading against RPM and MPH.
But yes, slipping in high gear, better clutch is needed. Boost control is about addressing wheel spin really. The clutch should be sorted first.
Threads: 41
3
(08-12-2014, 02:39 PM)Dum-Dum Wrote: The 406 2.2 HDi clutch (for which i have a dead one and a flywheel) is 240mm
And that fits the XUD9 and inside the BE3 bell housing ??
Then that's the one to use surely ?!?
Threads: 541
124
I assume that it fits all the other DW/XU series engines, it certainly looks right. If someone drops over a spare BE series box we'll see if it fits. I assume it does.
Threads: 42
28
unlikely it'll fit in a BE box, DW10 would be the largest you'll fit at 230mm afaik.
Threads: 591
54
(08-12-2014, 02:36 PM)welshpug Wrote: (08-12-2014, 12:36 PM)Piggy Wrote: XUD11 flywheel is heavier but not bigger.
Indeed the number 235 is bigger than the number 215
The xud11 flywheel however is identical in diameter to the xud9 one...hence why I went for the xud9 flywheel!
Threads: 591
54
When everything does hook up nice....damn she goes well.
I mean, daaaaaaaaaaaayyyymn. She is running well. Runs a little cool if anything. But I can live with that!
Threads: 386
87
It's like 4c out, not surprising it runs a bit cool atm lol.
Threads: 591
54
Aye but I drove to nuneaton and back. And hooooned a LOT!
Still did about 45-50mpg over the 100miles or so going by how little the needle moved!!
Threads: 386
87
The fuel needle? You should know you can't trust that.  50mpg's good considering though!
Threads: 591
54
Its very trustyworthy to be honest.
As is the light
Threads: 386
87
Dunno how you've managed that. I've never had an accurate 306 gauge lol. They are more accurate at the bottom admittedly. Usually have ~50 miles of the light flickering before it comes on solid, then know I could get another 50 miles with the light on. But above that it was more accurate to just guess how much fuel there was.
Threads: 226
24
Car Model/Spec: A3 TDi
Dibs if you give up
Threads: 541
124
If you get an ml box a 406 clutch will defo fit
Threads: 591
54
406 clutch is all good and well... But do they make uprated clutches for a 406!?
Threads: 541
124
CG will make you an uprated clutch for whatever you like.
Threads: 55
17
Car Model/Spec: 406 V6
12-12-2014, 12:16 AM
(This post was last modified: 12-12-2014, 12:18 AM by Rippthrough.)
You could do it the old pikey way and fit 2 diaphragms in your stock pressure plate. However, does give a weird feel over centre and the travel is exaggerated because of the play between the two. Also need left leg like He-Man.
Threads: 102
9
how the hell you got the new clutch slipping? not that long since you dropped a recon one in?
Threads: 591
54
Nope. About 2500miles i think
350-380ft lbs would do it though!!
Threads: 120
35
Car Model/Spec: Rallye/S16 & 175 megane
Given 40 thank(s) in 40 post(s)
Shouldnt buy cheap CG shite!
Dude just buy a helix and be done with it!
![[Image: 17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg]](http://i143.photobucket.com/albums/r143/matt-taylor/17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg)
Team Cyril
