Threads: 120
35
(01-11-2014, 09:01 AM)Niall Wrote: No point in skimming a head if it's true. I've never understood people who skim them regardless when the majority of the time, you can just take it to an engine shop and they will check it with a straight edge for free. Or you can do it your self if you have a straight edge.
(01-11-2014, 09:02 AM)Paul_13 Wrote: Get it skimmed FFS
I can see where you're coming from Niall but I'm part of getting it skimmed regardless.
If it's apart just get it done in my eyes, better doing the job once not twice
Theres only one way too resolve this...
Team Cyril
In hereford I could get it done for beers/£25 depending on how soon I needed it.
I need it back up and running by next week, my LOCAL engineers is witney. Their£140 inc the vat.
I cant see why the head would be warped but will get it checked anyway. There is serious downsides to just getting a skim if you dont need it. If the head is true and you skim it, how much will they remove...then you need to calculate how thick the HG needs to be...thats if they didnt take so much off that it is unusable!
And, as it turns out, the first HG issue I had when I built it up and it was pressurizing was my fault...not the head being warped
Threads: 120
35
I havent had to change a headgasket on the rallye in over 20k miles..
just saying
Team Cyril
01-11-2014, 11:57 AM
(This post was last modified: 01-11-2014, 11:58 AM by Piggy.)
(01-11-2014, 11:55 AM)Matt-Rallye Wrote: I havent had to change a headgasket on the rallye in over 20k miles..
just saying
Was that a bit of tapping I heard as you drove it off the dyno?
And I would rather do a HG once a year and have over 200bhp and twice the amount of torque of yours
Threads: 120
35
Team Cyril
01-11-2014, 03:51 PM
(This post was last modified: 01-11-2014, 03:51 PM by Piggy.)
So got the head off. Annoyingly a notification stopped the timelapse recording only 5min in so no video
Got pics though...
[attachment=19864]
[attachment=19865]
[attachment=19866]
And a xud11 headbolt vs ARP bolt
[attachment=19867]
HG looks ok tbh. Bit of blow between the cylinders.
Most concerned about the cracks in me cups
Any thoughts??
Threads: 31
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
01-11-2014, 05:49 PM
(This post was last modified: 01-11-2014, 05:51 PM by 306Dan.)
I asked the same queston on one of the 1.9's i did, i cant remember who but was told it was ok to reuse and they all do it
and a thread i read awhile back on them
http://306oc.co.uk/forum/thread-21923.ht...ecup+crack
01-11-2014, 06:44 PM
(This post was last modified: 01-11-2014, 06:50 PM by Piggy.)
They do, I am used to seeing the cracking but that one is particularly bad....better pic on its way...
[attachment=19873]
Threads: 31
Hmm I see what you mean, it doesn't look like a surface crack does it?
Threads: 136
11
Wouldn't risk putting that back on
Threads: 42
28
same here, there's cracks and there's CRACKS....
get it to a head specialist, it looks like that chamber has moved too, they can be changed in most engines.
Threads: 343
15
Given 3 thank(s) in 3 post(s)
From what was said in that previous thread about cracked pre cups I wouldn't worry to much, all tho could be worth getting them checked to be sure.
Your right welshpug it looks like its moved too
Hopefully spike has a spare for me
I know sod all about diesels but that doesn't look too good! Im assuming too much heat would of caused that?
Threads: 34
8
Given 8 thank(s) in 8 post(s)
It looks like a nice chunk of precup was ready to eat your piston tbh
Threads: 371
29
Car Model/Spec: ford fiesta
01-11-2014, 08:03 PM
(This post was last modified: 01-11-2014, 08:04 PM by bashbarnard.)
That does not look good, anyway you can get another decent head rather than a repair might be cheaper
Yeah that head aint guna be used again
Spikes got one for me. Have to do a rebuild on it. But no HG yet anyway so may not actually hold me back, just £30 of new gaskets/seals
Threads: 6
Car Model/Spec: kingfisher Dturbo
does look like quite bad cracking wouldn't be too long before the cracks lead to a leaking head if bits didn't fall in the cylinder first anyone worked out why they crack anything to do with injector flow?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
how did it look last time you had it off? are they actually loose in the head?
01-11-2014, 09:10 PM
(This post was last modified: 01-11-2014, 09:16 PM by Piggy.)
They had like one tiny minor crack on each.
I'll have a pick at them once I have my replacement head
[attachment=19877]
[attachment=19878]
Some more pics for the lovers n haters
So.
Thanks to spike, got another 2.1 head.
Stripped them both down today. Just the valves to remove. But I got a raging cold and feel like death so stopped!
Looks good though. Hope to have NO worn hydraulic tappets as I can pick the best from the two heads. Although the unknown 'new' head seems to have very little internal wear despite the horrid crusty and oily exterior!!
Whats odd is that the left hand valve hydraulic tappet head on each inlet pair is worn but not the right?!
Video just editing...
In other news:
[attachment=19898]
Wife working in Ciren, so picked those up for me! 4x Michelin SX MXX3s 205/50/15s.
£80! So they be the new boots for summer and track.
Considering new wheels but not sure yet.
Threads: 42
28
holy fuuuk, they're OLLLLD.
check the dates, but I really doubt they would be fit to use as anything but tyre wall.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Yeah man, I had a set of 17's on the Punto that came with tyres, they all went flat one by one at the most inconvenient times.
Thought it was people just being overly cautious but I've had it happen to me first hand now and I'd never buy old tyres again (unless they're purely for shredding with epic burn outs in a RWD).
Yeah they aint brand new obviously. Not that old though
Threads: 42
28
check the dates, but Longstone tyres sell them as tyres for 80's and 90's classics!
anything more than 6 years on a michelin is dicing with hard objects...
6 years? Is that roughly the same for all tyres? Pretty sure I've used tyres considerably older than that in the past lol.
03-11-2014, 08:51 PM
(This post was last modified: 03-11-2014, 08:53 PM by Piggy.)
Yeah 6yrs is on it. These arent that old though! Well stored too. No signs of age at all tbf. For the price I'll give em a go!
(they still sell them new fyi)
One pair of tyres on my 'clones were used on and off from 2009 to this year...they were getting on a bit when I bought them as well!
Keep meaning to check the date on the Focus tyres tbf...wondering if they're still original.
Threads: 102
9
(25-10-2014, 04:04 PM)Danny Wideboy Wrote: Probably thought you were an old lady out shopping or going to church.
sadly my rover doesn't go shopping that much or come out to play on a sunday.
Piggy have you found out what caused the head gasket to fail?
