81
Hi guys,
Hate the sight of the white oregons on the front of my car. Fondmetals wouldnt fit as they were catching on the calipers and I cant grind down any more of the caliper.
I am thinking 5mm spacers on the front to definitely clear them and once the pads have worn down then Ill take the spacers out again.
On ebay i see:
universal 4x108 spacers with 71mm CB for £6.
specific 4x108 spacers with 65.1 CB for £40.
Planning on getting the cheaper ones as I am not planning on running them for long. Main question is with 5mm spacers will i need longer bolts?
Thanks
Sam
Threads: 151
14
Car Model/Spec: 306 D-turbo
It is advisable as your taking 5mm thread out of the hub essentially but I would of thought it would be fine it's all down to you really
Personally If the bolt screwed in a few full turns I wouldn't bother
Team Doesn't own a 306
Yes you will need longer bolts. Do they take tapered? If so i have a set here brand new which may be good for you. I bought the, for my winis but were too long for me. Might suit you.
Also, the cheap ones have a bigger CB. I would imagine you want it to be correct as if you don't get it right, you might have a horrid wobble.
Threads: 169
91
As said, don't do this without longer bolts. It really isn't worth the risks!
Threads: 448
51
5mm is fine, I ran ouragans on my old 1.6 with 5mm spacers and standard bolts for well over a year! I still got at least 7 turns iirc
81
Niall I may come and grab them off you. Yeh outs the tapered ones I need for the fondmetals!
Threads: 448
51
Fuuuuuu man, I'd had them fitted by a mechanic as I was unsure of fitment
Threads: 12
The most thread you will ever need is half the diameter times pitch of the thread. Any more is there for the shits and giggles. So say m12x1.25 is 6 x 1.25 is 7.25 threads. You should be fine
Threads: 266
18
Car Model/Spec: 205 DTurbo
I run 20mm's on the Datsun becauseracecar.
Threads: 78
49
The Audi has been running 5mm spacers to clear the coilovers on the front for around 4 years. Can still get 7 turns with standard bolts, I'm happy with that. Just cheap universal spacers too, I just make sure they're centred by eye.
81
Went and saw Niall tonight and got some long bolts from Him. Better safe than sorry especially on track!
Threads: 21
Car Model/Spec: GTi6 Supercharged
I posted this exact question on the other forum earlier, but for road wheels, and 3mm spacers.
Will I need longer bolts? If so, where can I get them from?
Thanks in advance
Chris
1999 China GTi6 Supercharged track car
2000 Bianca LX non turbo slowness
Team: I hate Sam Rowell's stanceboard!
Threads: 183
20
App what's needed for 306 m12x1.5 or m12x1.25?
