Jonny's GT20s HDi Estate
Going well then?!
Yeah, it's got so much potential now! ! Smile
Can't wait for a video mate!!
^^ This!
VIDEO!
Not until I have a MAF lol
I hope your clutch will cope.
[Image: 704e7db1.jpg]
(24-01-2013, 07:31 PM)Birk Wrote: I hope your clutch will cope.
Oddly enough it seems OK after a couple of weeks sitting still :S
Haha, Wel let's hope it's going to cope with a new map.
I have my doubts.. But we'll see soon enough!
I may have missed or already asked but what clutch you got?
A 4 paddle CG, but it was 2nd hand, and slipped like a biatch. Seems ok now though.
My helix 4 paddle is holding strong mate. But it was re plated. That's with stage 2 map so if ures isn't mapped should b alright.
We'll see how it goes, can always whip it out and get it re plated if needs be..
Ok so i need to turn the boost down lol
MAF sensor fitted, go out for a drive, hit 25 psi so quick it was untrue, then the gauge went to 0. Bonnet up and it had blown the gauge pipe out of the inlet elbow Big Grin
I'll get under it at some point and back off the wastegate a bit, just have to drive gently for now though.
And I need a passenger to video, got one today but it's so bad I CBA uploading it.
Fitted my new lower brace this evening, backed off the WG arm while I was at it.
And managed to bodge my engine cover on over the brace, so it's a stealth brace lol
Do you not have any sort of boost controller?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Yeah but it was wound right out and still had too much preload on the arm
Ah ok, I got lucky when I bodged my actuator on, my controller works perfectly.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
I bet this is powerful once its all mapped up
S2 HDi >click<
154bhp
280lbs/ft
That's the intention Big Grin
Lol. That was fun. Now the boost is turned down its a bit laggier but feck me when it comes on blow
Its so much fun now!!
Wanna take me for a spin at rays?
What boost you running now?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
(31-01-2013, 11:21 AM)Ricky Wrote: What boost you running now?
Also interested...
Chris used to run 28psi on his, and it was making over 200hp before it exploded.
JP
JP
21psi max, but I reckon I over did it backing off the wg, it was picking up super fast before but it's now a bit laggy, there's not much under 3k. good news is that the clutch holds a bit better at that, but I want that early spool up that I know it's capable of.
Shouldn't be laggier if it's got a boost controller, surely, thought that was half the point of the things: eliminate wg creep..?
I'll take you out in it over the weekend mate. See what you think.
Depends what boost controller? Bleed? Ball and spring? Electronic.
Also, remember when you adjust the wastegate arm, you can inadvertently set the wastegate itself so that it either won't open all the way or won't close all the way. That's why I would always say, leave it set stock and adjust the controller to "hide" the signal from the actuator.
JP
JP
(01-02-2013, 11:31 AM)jammapic Wrote: Depends what boost controller? Bleed? Ball and spring? Electronic.
JP
Until the exhaust pressure builds up enough that it'll blow the wastegate open, so requires more preload...
  Jonny's Orange cabby (xud content!) Jonny81191 65 42,192 05-01-2015, 07:52 AM
Last Post: 1616six
  Carl and Jonny's XUD Hillclimber 306racecar 151 114,076 15-10-2014, 11:47 AM
  Jonny's 406 executive HDi Jonny81191 38 21,509 07-02-2014, 06:44 PM
Last Post: Jonny81191
