LDA pins, Injector refurbs, Pump mods blah blah
ok mate when you get sort i will be after 1 cheers
#32
Hi, new guy here. I have a 406 but have read a lot on this forum and others about the LDA mod. I'm after a ground pin, if you can help Dan? I can't PM you, presumably due to my low post count. Cheers.
#33
Hi Ally, yeah that should be fine. Do you want a ground pin sent to you (£20) or would you want to send me your pin, have it ground and then returned to you? (£13).
Thanks.
#34
Did you get a price on refurbing my injectors mate?
#35
If you could send me an already ground pin, that would be great! Perhaps you can PM me you email address and we can get something sorted out.
#36
Sorry Jonny, busy couple of days. I'll check the prices tomorrow for you x
Ally, sounds good man. PM incoming.
Edit, Okay, your PM system is totally disabled at the moment. I'll put my email below and once you have seen it let me know and I'll edit it out.
danhargrave at live.co.uk
#37
Can u grind pins yet, as I can send 1 to u if so?
#38
I should be able to start doing pins this weekend and injectors/pumps soon after that. I'll pm my address and PayPal to all of you tomorrow :-)
#39
Yay, now where did I put my spare set of injectors ...
#40
Thanks
#41
I just noticed that I can't access the messages yet (low post count). If you've sent me a PM I won't be able to access it. If you don't mind forwarding it to evilally at hotmail dot com that would be great.
#42
Dear Dan!
I would very very VERY much like to book my car in with you as the bloody thing used an extra quater of a tank getting back to camp then i normally does
Hoping your ok
David Mowle Smile
#43
Just received my LDA pin back from Dan, can say he's done a great job! I will send my injectors to you next month wen I have funds!
Cheers Dan!
#44
Got my pin today aswell Dan nice one buddy Smile
[Image: J5hxCcC.jpg]
#45
Reasons for griding original LDA pin as to making your own...
[Image: 20121019_161125.jpg]
this was a custom made pin, the problem is that it is extremely difficult to get a hardening process correct....or should i say as good as original item. It is a shame as it worked a treat for a perios of time but just wasnt hard enough Smile
CJ
#46
this the pin from the RR meet. looks paggerd. were you get it from
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
#47
I have a pin that looks like that :/
(19-10-2012, 03:22 PM)CJ_Derv Wrote: Reasons for griding original LDA pin as to making your own...
CJ
#48
Got it off a good mate a while ago, but now got dans pin in and made a huge difference as its not getting stuck
#49
gutted you so far need a pump change
#50
First set of injectors done for zx_volcane.. :-)
#51
^^^Shiney bits Big Grin
#52
Can you get uprated tips dan? This would be HELLISH epic if you could!!
#53
(24-10-2012, 09:57 AM)Dave Wrote: Can you get uprated tips dan? This would be HELLISH epic if you could!!
was thinking this also Smile
#54
Shiny indeed Smile
(24-10-2012, 08:34 AM)Dan! Wrote: First set of injectors done for zx_volcane.. :-)
#55
What's the turn around time on injectors?
#56
I can get in any nozzles/tips that you want, although its not as easy as just phoning up to order them and asking for uprated ones, id have to research which tips would fit and if/how much they would flow higher. Id like to do this but its not something iv done yet, Toms nozzles are an upDATED version of standard nozzles, 299c's instead of original 299's, but afaik they are just updated oem, not higher flow...
Turn around time, if you post them first class they will be with me next day, i can then refurb them and send them back first class the next day. So for example if you post them monday, il get them tuesday, refurb them tuesday night, send them back wednesday and they should be with you thursday.
Thats for a standard refurb with no new nozzles, just stripped cleaned etc. If you want new nozzles youd have to allow an extra day for delivery of nozzles.
Cheers.
#57
my pump and injectors should be with you today mate...cash inside -_-
#58
Goodo cheers mate. Got a text from my stepmum earlier saying i have 2 parcels at home, should be one of them i reckon! :-)
#59
hope so,can't wait dan to get it all on.gonna be busy when it comes back...got gmax superstrut gas dampers plus need to lower the torsion,gmax 60mm front springs,oil return pipe,td04l turbo,adapter plate,cambelt kit,glow plugs,pump,lines and injectors to put on -_-
#60
If you can get hold of uprated injectors that would be brilliant, and I'm sure you'de get some excellent business too...
  Bosch and lucas injector pump sprockets. ConorTRG 4 4,248 24-08-2013, 01:26 AM
Last Post: ConorTRG
  Lucas to Bosch changing pins on bracket? Danny2009 3 4,417 12-02-2013, 03:39 PM
Last Post: Danny2009
  406 pump mods philb 5 7,357 14-08-2012, 04:28 PM
Last Post: philb
