Lucas to Bosch changing pins on bracket?
I have head you can move the threads on the bracket instead of using a Bosch bracket
Hat do you actually do just move the 3 studs into the spare threaded holes? Can't be that simple or is it?
Cheers
Team Doesn't own a 306
just double nut them and move them to the other holes pretty simple tbh, i know this and i haven't got a clue were to start with a bosch conversion lol
Like chris said 2 13mm nuts onto the stud, nip them tight together then wind out Smile.
I've done a few conversions but always used a Bosch bracket
I thought that's what you did but just wanted to check
Cheers lads
  Substitution pump Lucas with Bosch AmedeoRS 3 3,946 13-05-2016, 08:36 AM
Last Post: toseland
  Lucas to Bosch Conversion Phase 2 306 DTurbo FrostyHDI 2 3,388 01-12-2015, 02:43 PM
Last Post: Dave
  Bosch pump to bracket bottom bolt blinkyeatu 5 3,703 30-09-2015, 06:48 PM
Last Post: Uberderv
