how the f'ing f do the p bush big bolts go in?
Done them afew times before, 15 min job stright tho and nut on. I have broke a rachet strap trying the get the bracket down to be able to get the nut on now.
How do you do it?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I usually put the little one in first as it helps pull it down, then I use a lever bar to push the arb down to get the bolt through
Sure the ARB bushes are in the groove? If so, big g-clamp...
Pretty sure ye, The little one and p bush goes down fine its the clamp over the ARB bust that wont go down. The gap in the bush goes to the front correct?
Blaze 1.6 Dead
I would estimate that your clamp is not fully engaged in its subframe slot, and you're trying to bend it instead of move it to position.
I usually do the long bolt first as there is play in everything then.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Hmm, I think the gap was to the rear on mine, but not sure, been off for a long time!
changing your arb for a thicker one? if so get the right size bush's Wink
No standard one going back on
Blaze 1.6 Dead
Take drop links off? No tension then?
I did it by putting small bolt in then getting sissor jack under the ball joint wind it up and it drops the p bush down at the back so you dont have to try and push it down
Get both sides jacked up makes the job so much easier
[Image: signiture.jpg]
yah much better to jack up both sides so arms are near level...less strain on your nice new bushes too
There is no strain on them atm the wishbones will move up and down fine, Its the bushes on the ARB but there not new there as it came off
Blaze 1.6 Dead
but the bushes on the anti roll bar will be under strain with one wheel on the ground
There are no wheels on the car or suspension
I fitted the coilover to one side to make sure it fit as it was from a 206 then removed it so its stood on stands atm with nothing in the arches
Blaze 1.6 Dead
Well in that case, it's just you being a fairy.
ah cool I get you, and I agree with rippthrough then Smile
(02-12-2012, 04:40 PM)Seb_Ryan Wrote: Take drop links off? No tension then?
having had mine off and on a million times this week i can confirm that this ^^^^^ is what you should do . . . . piece of piss then, take both sides off though . . .Smile
  P Bush PocketFighter 7 5,256 09-08-2016, 04:47 PM
Last Post: PocketFighter
  p bush upgrade tuttyboy84 9 6,053 14-02-2015, 06:25 PM
Last Post: tuttyboy84
  Which wheel bolts? / WANTED - oe +20mm bolts laurence_13 5 5,494 15-02-2014, 10:59 AM
Last Post: Mattcheese31
