Which wheel bolts? / WANTED - oe +20mm bolts
Just swapping my wheels over so I can get one set refurbished and put some spacers on... The bolts that came with the spacers have a tapered top where the standard size bolts don't, I'm guessing one sets for alloys and the other for steels? But which way round is it... And are the tapered extended ones going to be ok on the smr speedlines or will they ruin them?
Sorry for my ignorance!
Cheers,
Laurence
Now that's established - does anyone have any oe +20mm bolts lying round I could buy?
yes the tapered bolts will ruin them . . . .you need the flat seated for the OEM wheels mate . .Smile
Thought as much... Cheers!
no probs . . Smile
(15-02-2014, 10:46 AM)Mattcheese31 Wrote: no probs . . Smile
Repped.. Keep forgetting that! Haha, are the bolts for smr's and genuine speedlines different? They look more chamfered...
no mate, there is some slight variations in the flat bolts, some have a slightly longer unthreaded section in the middle but they all do the same job . .Smile
  3mm spacer need longer bolts ? carlukepeugeot 0 1,943 22-04-2018, 01:10 PM
Last Post: carlukepeugeot
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,322 04-01-2018, 11:40 AM
Last Post: Mighty306
  Brake caliper mounting bolts Mighty306 4 3,733 22-07-2017, 09:49 PM
Last Post: ben10241
