31-01-2015, 02:32 PM
I need a new wishbone and ive read on here that the partner p bush is a good upgrade, can i just buy a partner wishbone to replace mine and then it should have the uprated bush fitted or will it not fit?
p bush upgrade
31-01-2015, 02:57 PM
Think you need a bigger bolt there's a thread in it somewhere
31-01-2015, 03:09 PM
Just get the partner p bushes fitted onto your current arm, genuine arms are heaps better than aftermarket ones which can fail, i had the front bush literally snap off at 50mph not cool
31-01-2015, 03:23 PM
How will i know if mine are oe as its an old car so may have had wishbones replaced in the past???
31-01-2015, 03:29 PM
normaly the oe arms have bolts holding the balljoint on and the patern are rivited
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
31-01-2015, 03:41 PM
Also which are the best p bush to buy as there are loads of different ones on ebay
31-01-2015, 04:15 PM
31-01-2015, 04:36 PM
o.e are not rivetted.
31-01-2015, 10:00 PM
14-02-2015, 06:25 PM
Ecp sell twr partner p bushs and ocap ones has anyone used the ocap ones or should i just go for the twr's
| P Bush | PocketFighter | 7 | 5,526 |
09-08-2016, 04:47 PM Last Post: PocketFighter |
| Fitting new P bush | Welshy_Pete | 1 | 2,411 |
27-01-2014, 12:45 PM Last Post: mcglynn |
| how the f'ing f do the p bush big bolts go in? | HDIkyle | 17 | 11,382 |
23-08-2013, 01:58 PM Last Post: Mattcheese31 |
