Alittle help with handling.
right just want to say here: I was NOT driving hard/stupid.
i was driving at a normal pace, slight rain and going round a large roundabout when the backend steped out.
for some reason its started to feel 'wobbly' lately, tires are all fine, and as far as i can see everything is intact.
was it just having a moment? or is it a common problem I.E. rear mounts, Bearings, ARB??
thanks for any help
Diggers
[Image: sig-1.jpg]
SOLD
Rear beam mounts are the likely suspect!
Check the shocks for leaking and check the beam mounts.
Mine's the same and I know my rear beam mounts aren't good... Likely suspect.
Best thing to do is just jack it up and take a look, give everthing a shake, kick and wobble, could be anything suspension related.
Stage 2 XUD Sedan
so beam mounts suttin to defo look at?
Time for solid mounts? might as well upgrade while im there?
[Image: sig-1.jpg]
SOLD
That's what I'm doing, get your name on the list
(30-08-2012, 07:31 PM)Curt Wrote: That's what I'm doing, get your name on the list
list??
dont make me laugh :p
DIY FTW
another project for me to make, that reminds me got to show my latest project :d
[Image: sig-1.jpg]
SOLD
lol fair enough Ben. What's this new project of yours?
You say it happened in the rain?
Not running spec 2's are you? Lol
I've got dodgy P-bushes on mine and that seems to make the back end nervous when it's wet...
(31-08-2012, 06:16 AM)THE_Liam Wrote: I've got dodgy P-bushes on mine and that seems to make the back end nervous when it's wet...
funny you should say that, my n/s p bush has split, maybe thats apart of the problem too
[Image: sig-1.jpg]
SOLD
It'll pull all over shop in the wet with tired p-bushes.
(31-08-2012, 05:33 PM)Rippthrough Wrote: It'll pull all over shop in the wet with tired p-bushes.
Maybe new bushes is first thing to try
[Image: sig-1.jpg]
SOLD
jack it up, then give it afew "gentle" taps with a regulation size tapping stick (persuasion maker) if it rattles of flex's then upgrade it Big Grin
Solid beam mounts, i cant drive without them now
  Estate handling mods Tabbiss 2 3,461 24-10-2019, 04:53 PM
  Scary rear handling! plugy 11 9,544 15-06-2018, 12:37 AM
Last Post: plugy
  Dreadful Handling JTaylor2005 39 19,421 01-05-2016, 09:45 AM
Last Post: Paul_13
