Estate handling mods
Hi everyone, I’ve got a meridian hdi estate and I want to start getting some more power out of it. I want to make it handle better as well but still dailyable. Any advice would be appreciated.
chassis is the same as the hatch so everything will bolt on, some estates have 21mm torsion bars same as fitted to the xsara vts, up from the xsi/gti6 20mm, check what you have.
xsara vts beam is a good upgrade. Fit some Bilsten B8s on the front and B4s on the rear. Stage 1 remap is from 90 to 125hp with no supporting mods.
  Scary rear handling! plugy 11 9,863 15-06-2018, 12:37 AM
Last Post: plugy
  Dreadful Handling JTaylor2005 39 20,368 01-05-2016, 09:45 AM
Last Post: Paul_13
  Handling on a worn out rear beam? JTaylor2005 11 7,625 10-08-2015, 04:26 PM
Last Post: JTaylor2005
