cig lighter how does it work
if i use the cig lighter to light a fag it works
but if i plug my phone charger or sat nav charger they dont work but they work in my other car
any ideas
is the plug going all the way in? had it in my old 306 that it would push in and feel like it was in but wasnt getting any power
Maybe to do with the earth part of it
if you look into the lighter socket you will see two tabs oposite each other these are bimetal strips that bend out with heat releasing the lighter end
i suspect these have gone week and are not gripping your charger lead
you were 100% right
thank you
now fixed
(06-08-2012, 07:07 PM)cully Wrote: if you look into the lighter socket you will see two tabs oposite each other these are bimetal strips that bend out with heat releasing the lighter end
  Cigarette Lighter Problems bigcheez2k3 6 5,980 08-11-2017, 04:55 PM
  Cigarette lighter not working toughmat 7 4,918 19-07-2013, 08:28 AM
Last Post: TrinityJayOne
  cigarette lighter with ignition? TheCrimson 14 7,720 05-05-2012, 08:35 AM
Last Post: MattDM306
