Cigarette lighter not working
Simple really got a phase 3 nad and the ciggy lighter has stopped working.
Plugged in my sat nav to charge and behold no charge.
Is this a simple fix to replace or is it just a matter of replacing the fuse???
Thanks Matthew
I would find out what fuse the cigar lighter uses. Then pull it out and inspect it. If it just went out of the blue its probably that!
do you know what the fuse number is on the fuse box
Pull em all out and see what ones are blown lol
If you google it you can get fusebox layouts, they should have a rough idea. Or just pull them out one by one.
Its working now for some bizarre reason lol, will keep an eye on it
They can be a little temperamental sometimes. New units can be had on eBay for a couple quid
Make sure it's not the charger itself. I had a similar issue, phone wouldn't charge but worked ok in my brother's car (not a Peugeot). It was just a simple HTC charger with a micro USB connector, was lighting up ok but wasn't doing anything. I went out and bought a Samsung one and haven't had any issues since.
  Cigarette Lighter Problems bigcheez2k3 6 6,158 08-11-2017, 04:55 PM
  cig lighter how does it work omega 4 3,844 08-08-2012, 03:00 PM
Last Post: omega
  cigarette lighter with ignition? TheCrimson 14 8,017 05-05-2012, 08:35 AM
Last Post: MattDM306
