Spraying interior trim
Spraying my 'a' and 'b' pillars matt black and wondering what would be the besst method?
Plastic primer then matt black?
Ordinary primer then matt black?
Or can i get away with just spraying matt black?
Also has anyone had a go at spraying the grab handles on the headlining black?
Thanks Smile
Normal paint will chip and crack iirc, you. Need a special paint that's flexible
Normal primer has a tendency to flake. A good key, plastic primer and matt black would be fine.
Thanks.. Don't know whether to spray the handles or not...
I've seen handles done before, just don't know about a and b trims as someone I know sprayed the dash etc and it all cracked and looked shit
I thought the handles would be most likely to crack as they would be getting handled most? Ill have a go anyway it will be a learning experience...
Good coat of plastic primer and some Matt black paint. Let it dry properly somewhere warm and jobs a goodun. I've done all of my roof plastics in Matt black and they look fine!
I've done my interior lights and grab handles in sea grey. Don't think I primered it but make sure you put lots of lacquer on.
Don't need to lacquer it really. Just make sure the plastic is nice and clean and you get a really good coat or two of primer on.
I have the plastic primer here so ill throw a good coat on anyway thanks niall and sam
I primed and sprayed my old cars pillars, never had any problems with paint flaking, as once they are on they dont get handled
Sprayed everything and it turned out perfect
  Painting/wrapping interior trim Iceman299 4 3,481 04-10-2015, 04:44 PM
Last Post: Slam Wagon
  Wing mirror interior trim question clarkey2010 3 2,711 06-08-2015, 07:03 PM
Last Post: welshpug
  Interior Carpet Trim Issue Orta 2 2,664 24-11-2014, 11:52 PM
Last Post: Orta
