URGENT!! Fuel filter change now its F**KED!!?
As above, did an oila nd fuel filter change...
Following the filter change the engine stalled and wouldnt restart. This was only coming out of my road. I checked the filter housing and there was diesel in it, the car decides when it wants to start and stall... it needs pre-igniting a few times before it will run and how long it runs for completely varies... Now thats been like that for an hour of trying to hold it running... it now fires first time and drives but the power is limited to 2.5k rpm...]
All over a filter change?! I did put the old filter back in for now
Please help, this car has got to be spot on for the weekend
Ta
James
Sounds like it isn't sealed properly and getting air in the system.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
As above. And make sure you use genuine fuel filters on the HDis.
So you had issues for a few hours and ended up putting the old one back in, and now it works fine, or it's still going wrong?
Dave
ignition on for 10 secs, off for 5 secs, do that 6 times and it will prime the fuel system. also replace the seal on the lid otherwise it may not seal properly, if its a quality filter it will have one in the box. try a Hengst filter from euro car parts, always use them at work and never have problems
something hasnt sealed properly; causing air to be brought into the system--causing hard starting and the inability to rev up prperly. either the lid o-ring or perhaps a pipe you have removed/refitted ?
  Fuel Filter pug306driver 8 6,789 25-01-2019, 09:50 AM
Last Post: pug306driver
  fuel filter housing changed jason68 6 5,141 08-01-2018, 02:14 PM
  fuel filter body removal pug306driver 9 6,164 07-06-2016, 06:48 AM
Last Post: Paul_13
