Gearbox mount issues
Been having a few teething issues now with cracked turbo brackets and bolts shearing off.
[Image: 4cacfd4bd6125669409b461c93d0cfb1.jpg]
[Image: a794b3385b254d28d943d07c5390720a.jpg]
Admittedly the first bracket was an incredibly poor lash up to get the car back on the road. After that i tig'd up all the shit welds filling them right in and then triangulated the arm to add additional strength.
[Image: b1aa902f659a3817a657d3f5461d9559.jpg]
[Image: c823a441167874708b85a9670b9c5b5c.jpg][Image: 614511cd2d66d3742ac3c23f1a06cad4.jpg][Image: 05c42df637b6ccfa992c69e076d47ac5.jpg]
This time tye bracket failed on the piss poor mounting point and poor bolt choice.... 2x stainless m6 bolts that hold the chra in the exhaust housing.
[Image: 26439102a399ea7f750ef21e9262b531.jpg]
Ive now over engineered the bracket adding a further mounting point, triangulating the whole frame and using high tensiles on every fixing point.
[Image: 8464a1cdc99997efbfbe30db27ab2e27.jpg]
It was suggested to me that this may be failing due to heat expansion and was advised to fit a flexi pre turbo. Now ive never actually heard of this being done or seen it in anyone elses projects so was wondering if this is a feasible remedy. Slightly concerned the flexi may not hold the back pressure and temp as i can peak upto 40psi back pressure on a spike and 800deg c in temp
Opinions???
Sent from my BLA-L09 using Tapatalk
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
your welding is improving, there are 4 8mm studs nearby.....8 if you include the allan bolt holes.....engine is gunna move quite a bit due to all that power on drive and overrun......
use HT fixings not SS, twice as strong.
Also is the downpipe bolted to anything but the turbo?
  Gearbox engine mount DeeTurbo 15 7,656 17-06-2016, 08:46 PM
Last Post: DeeTurbo
  need a quick answer gearbox mount jays306 8 4,885 09-09-2013, 12:36 PM
  Lookin 4 a gearbox mount Choppin 10 5,979 07-11-2012, 09:50 AM
Last Post: Choppin
