12-04-2016, 06:10 PM
A 307 hdi with a blocked dpf may be coming my way very cheap so is anyone doing cheap maps with dpf removal i believe it will be a 110 with bosch management
Anyone on here doing remaps?
12-04-2016, 06:37 PM
12-04-2016, 06:43 PM
Yeah ive just seen he does a dpf removal for £30 so ill proberly just do that and sell it on for a profit
12-04-2016, 11:42 PM
You mean the dpf, or the map?
/Toseland
13-04-2016, 06:32 AM
Feel free to correct me if im wrong but you can't map out a blocked DPF. When it's blocked the engine registers it and keeps trying to regen so if you map it out it'll just keep regenning all the time.
Need to have it unblocked then it can be mapped out and removed , remove it from the car then try soaking in caustic soda and jet blasting out any crap to see if you can get it clean enough for the car to register it's not blocked any more
13-04-2016, 06:52 AM
you can alter it so its not looking for the dpf.
then remove the dpf. simple.
13-04-2016, 08:09 AM
And im going to drill the dpf out so its not blocked anymore
13-04-2016, 09:16 AM
depends which type, i've done some that you can unbolt, just smashed it out with a scaff pole
13-04-2016, 09:39 AM
Well im crossing my fingers its that one then lol
13-04-2016, 09:49 AM
There are two types, one unbolts, and one you need to cut it open and weld it.
It's actually easier when you cut it open as you can pull the whole lump out rather than drilling it, but you'll need a welder.
13-04-2016, 10:34 AM
indeed, it actually took less time to decat my BMW than it did to sort out a mates 2.2 406 coupe.
13-04-2016, 12:19 PM
chain pipe cutters... job done!
/Toseland |
Cheap remaps | sherman306 | 1 | 922 |
03-10-2016, 01:07 PM Last Post: zx_volcane |
Mr Whippy.... Is he still doing remaps? | td163 | 21 | 5,164 |
30-04-2015, 11:31 AM Last Post: pro_steve |
Remaps | Chris HDI | 6 | 1,435 |
28-02-2015, 07:39 PM Last Post: Chris HDI |
