This flywheel sensor?
I need a new rev counter sensor fro my xud 1.9dt , Is this the correct one? They have in the description TDC sensor?
http://www.ebay.co.uk/itm/TDC-Sensor-Fly...567995dfc9
No this is it:
http://www.ebay.co.uk/itm/SPEED-SPEEDO-R...231ae728b4
My zx xud uses your link pugtk, looks about right Smile
My 205 uses this type, http://pages.ebay.com/link/?nav=item.vie...56&alt=web
Not that I can get mine to work !
So depends what car its going in.
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
(07-09-2015, 11:17 PM)ConorTRG Wrote: No this is it:
That's a speedo sensor not a flywheel sensor Rofl
(08-09-2015, 09:20 AM)andyyy Wrote: My 205 uses this type, http://pages.ebay.com/link/?nav=item.vie...56&alt=web
Hi Andy, its actually going in a 205 d turbo, and that connector looks like the correct one.
I was going to just solder the 306 connectors on as I couldn't find a 205 one.
However , it doesn't seem compatible with the 205 d turbo, I tried using there compatibility function on there page.
Although It looks pretty much spot on
I just bought one and it plugs straight into my 205 loom, I tried soldering the connectors from a 306 one previous and that didn't work for me.
I found the part number on service box for my 205 so assume it's correct for 205s.
I'll update if I figure out what's wrong
(08-09-2015, 04:03 PM)andyyy Wrote: I just bought one and it plugs straight into my 205 loom, I tried soldering the connectors from a 306 one previous and that didn't work for me.
Is yours an original d turbo or did you fit the d turbo clocks to a base model dash?
Mine is a gti loom with stdt clocks
By any chance would you have the part number?
Thanks
I assume it's 616070 as that's how I found that part.
You can double check on service box yourself iv forgotten my sign in details and nowhere near my PC to get them.
Service box?
google mother trucker!
see link in my sig.
I can confirm that sensor I posted 100% works in a 205 with stdt clocks
(29-09-2015, 06:28 PM)andyyy Wrote: I can confirm that sensor I posted 100% works in a 205 with stdt clocks
Get your clocks working?
Ordered Big Grin
So I've the sensor ready for fitting, what gap does it have to be set from the flywheel? Ive the feeler gauge ready to go Big Grin
Now im just hoping I did refit the 205 flywheel, instead of the 306 one, (wondering if the pickup points are in different locations ) Big Grin
I just pushed it in until it goes no further, ie touching the flywheel. I'm using a 306 flywheel so can't comment, but did use aa 205 sensor bracket thing if you know what I mean.
(17-10-2015, 02:56 PM)andyyy Wrote: I just pushed it in until it goes no further, ie touching the flywheel. I'm using a 306 flywheel so can't comment, but did use aa 205 sensor bracket thing if you know what I mean.
Its working now Big Grin
All electrics working, bar central locking, so thats next on the cards Big Grin
  Crank/Flywheel sensor Martin306 1 2,182 10-03-2015, 08:28 PM
Last Post: Martin306
  Is this the correct flywheel sensor? pugtk 1 2,255 17-02-2015, 11:49 PM
Last Post: vinny
  flywheel sensor pugtk 8 5,760 27-01-2015, 07:10 PM
Last Post: Alex
