Is this the correct flywheel sensor?
Hi All,
Will this xud flywheel(rev counter) sensor work with my 205 dturbo?
I have the 306 connection for the loom side, so I can change the brown plug on the 205 to the 306 one.
http://www.ebay.co.uk/itm/TCC-Sensor-Fly...566f09795f
listed as a tcc-sensor?
if the back of ur flywheel has the notches to trigger it yes its the one but their is onther plastic part that it pushes into thats bolted on the back of the cylinder block u will need that too
  Correct type of thermostat? carlukepeugeot 1 2,601 02-09-2017, 06:13 PM
Last Post: bashbarnard
  This flywheel sensor? pugtk 16 8,614 25-10-2015, 04:04 PM
Last Post: pugtk
  Crank/Flywheel sensor Martin306 1 2,185 10-03-2015, 08:28 PM
Last Post: Martin306
