08-03-2015, 06:25 AM
Managed to get some cyclone wheels to replace the standard meridian ones, but the bots are different so if any 1 can help
Thanks
Thanks
Wheel bolts for cyclones
Thanks
08-03-2015, 07:31 AM
there are two types of clones
early set take a flat seated bolt that has no tapered shoulder later clones have a counter bore in the bolt holes which accept the later bolts that have a shoulder which secures the steel spare wheel
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
08-03-2015, 07:51 AM
ive got a set of the later ones inc locking bolts if you need them.
08-03-2015, 04:53 PM
08-03-2015, 04:56 PM
(08-03-2015, 04:53 PM)SACHAx Wrote:(08-03-2015, 07:51 AM)welshpug Wrote: ive got a set of the later ones inc locking bolts if you need them. later ones are the bolt on the left in the picture https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
08-03-2015, 05:57 PM
(08-03-2015, 04:56 PM)cully Wrote:(08-03-2015, 04:53 PM)SACHAx Wrote:(08-03-2015, 07:51 AM)welshpug Wrote: ive got a set of the later ones inc locking bolts if you need them. I think it's the early set I need then mate, as the standard 1s off the meridian wheels I believe look like that then?
08-03-2015, 06:22 PM
I thought it was the GTI ones that had just the flat seated bolts as the spare was an alloy, whereas the other type was off the meridians etc, and ran a steel spare hence the taper?
08-03-2015, 09:17 PM
09-03-2015, 10:44 PM
You have a pm
09-03-2015, 10:51 PM
(09-03-2015, 10:44 PM)Dale Wrote: You have a pm They won't be able to reply to it, as they don't have enough posts. This seems a bit like a "Wanted" thread to me, so should be in the Wanted section, but then the OP can't post in there either due to lack of posts. Naughty naughty.
09-03-2015, 10:54 PM
(09-03-2015, 10:51 PM)WiNgNuTz Wrote:(09-03-2015, 10:44 PM)Dale Wrote: You have a pm Ooooo I see they best get posting in that case
| Alloy Wheel Bolts | rdstars | 2 | 2,743 |
16-03-2017, 05:01 PM Last Post: rdstars |
| Wheel bolts | PugRory | 11 | 6,651 |
09-11-2015, 11:55 AM Last Post: PugRory |
| c5 steel/alloy wheel bolts | Poodle | 8 | 5,957 |
20-04-2015, 08:42 PM Last Post: Poodle |
