Alloy Wheel Bolts
Sorry it's my first post,
Can anyone tell me the length of the Alloy wheel bolts for the Peugeot 306 from the flat of the washer to the tip of the thread.
I have a Peugeot Partner and have bought a set of 205 GTI Speedline alloys, the standard length of the Peugeot bolts are 35mm from flat to tip and am barely getting 2 threads and have read that the  306 Alloy Wheel bolts are a good alternative so am just checking first.
Thanks
306 bolts are the same part numbers mostly.
check you haven't got the late type bolts with a large taper under the head.
van front hubs in essence are identical to 1.9 205 bar lower bj size and geometry.
drive flange is the same part number.
I had a few spare standard Peugeot alloy wheel bolts, looking on ebay it seems 35mm from flat of washer to tip of the thread is the most common. But googleing most of the day and it seems the 306 Alloy wheel bolts are the one's mentioned for the Speedline 205 GTI alloys.
Just hoping someone could measure from the flat of the washer to the tip of the thread, I'm guessing if they are longer they should be around 40mm.
Cheers
  Alloy wheel stamp. Pugwash 5 5,370 05-06-2018, 03:15 PM
Last Post: Pugwash
  Wheel bolts PugRory 11 6,841 09-11-2015, 11:55 AM
Last Post: PugRory
  c5 steel/alloy wheel bolts Poodle 8 6,064 20-04-2015, 08:42 PM
