Fitting new P bush
I have removed the lower arm and removed the old P bush as well. But I'm just wandering whats the best way to get the new P bush in the right position to go back in right.
I know the right way around it goes in but getting the angle or amount of turn right is the main problem.
Thanks
you just put it straight, or angle it a little. get a look at the wishbones with the wheel on the ground and see what level its at, then set your p bush to this level.
eg. if your car is lowered you would angle it more, its pretty simple.
  P Bush PocketFighter 7 5,664 09-08-2016, 04:47 PM
Last Post: PocketFighter
  p bush upgrade tuttyboy84 9 6,697 14-02-2015, 06:25 PM
Last Post: tuttyboy84
  how the f'ing f do the p bush big bolts go in? HDIkyle 17 11,589 23-08-2013, 01:58 PM
Last Post: Mattcheese31
