handbrake/low fluid light on dash
Past couple of days my brake fluid/handbrake light has been coming on and staying on , car has plenty of brake fluid, no detectable leaks and good discs and pads all round , light gets brighter when I put thehandbrake on and dims when I take handbrake off
Any ideas people
I also have lost my left hand indicators but I can get them to work if I fiddle with the stalk a little but I wasnt sure if this may be connected to the warning light problem
Indicators will be a stalk issue, if you are capable enough you can take them apart and clean them. I also have the fluid warning light problem, I suspect a dodgey handbrake switch but it hasnt bothered me enough to try and fix it as it only happens every now and again
Mine is on all the time pretty much atm Sad
  Handbrake Light while driving MY95 23 12,354 12-05-2016, 07:14 PM
Last Post: DeeTurbo
  how many things does handbrake light represent? dr_jekyll 7 5,163 02-04-2015, 09:42 PM
Last Post: Vpricey
  Abs light & handbrake light. mcglynn 4 4,162 17-12-2014, 11:01 PM
Last Post: mcglynn
