Engine trouble
So driving along, everything fine. Suddenly engine gets a lot louder, a lot more rattly and knocky. No power, well lack if power, black smoke while driving, haze of smoke on idle, will stall every now and then,
Nothing changed, didn't hit anything, no clunks or bangs. Just happened
Timing slipped on pump...that's my shout, don't drive anymore, change cam and aux belt Smile
Damn you think it will knacker the pump if driven? I drove it home from town :/
No, it's just if it slips anymore, valves may hit things lol
Fair enough Smile so new cambelt and aux belt then?
That's all I bloody need!! Aha
Sounds like it mate, unless you got a stupid boost leak but can't think why she'd stall if it were that...
Agree with Mr cheese there. Sounds like timing has slipped, stop driving it immediately and get that belt sorted!
HDi Cabby Project Click
holla if you need a hand/tow..
Also have a free grill and badge waiting here for you Smile
Sweet. Ginge I'll give you a message some time this week Smile
Cheapest place to buy? And what is the proper name for an aux belt? Or am I being thick. It's totally slipped my mind what I'm looking for
Auxilary belt/serpentine belt/fanbelt, no need to replace it tbh unless its worn. btw theres 2 different timing belt kits the back plate on the idler pulley is the difference between the 2.
I would be investigating WHY its slipped!!
If it's slipped its probably because some aux belt has got caught up in cam belt, hence why I said to replace them both Smile
Matts in the ball, checked my aux belt, there is a chunk missing and a fraud but, guess they got mashed together
(01-10-2014, 01:50 AM)ConorTRG Wrote: Auxilary belt/serpentine belt/fanbelt, no need to replace it tbh unless its worn. btw theres 2 different timing belt kits the back plate on the idler pulley is the difference between the 2.
So which one am I gunna need? And what am I looking for too tell the difference? What does the back plate look like? Are the belts themselves the same? If so might just replace the belt for time being till I can affor to do the whole hog
Just get a 1.9DT cambelt (I believe they're all the same)
Aux belt is a little more tricky. I found the different PAS pumps have different sized pulleys.
Does yours have AC?
Not sure on your motorfactors, but just take your old one in to match to a new one there will no doubt be a few variants for the XUD
But you do need to investigate why the aux belt moved off track. Tensioner on the piss/belt slack/etc
When in doubt, rip it out.
(The engine).
(01-10-2014, 01:13 PM)Matt Wrote: Matts in the ball, checked my aux belt, there is a chunk missing and a fraud but, guess they got mashed together
I most certainly am not in the ball, or in any way living inside a testicle Big Grin
Check the timing first before buying anything
Will try and get it checked tonight
Checked prices and its like14 for a Campbelt and 3 quid for a.drive belt which I'm guessing is the aux belt as its so cheap
(04-10-2014, 11:34 AM)Matt Wrote: Will try and get it checked tonight
no, 3 quid is too cheap, should be about a tenner or so for aux belt and 20 for cam belt approx x
  Still in trouble with Timing. locodriver 65 2 2,597 10-03-2015, 05:20 PM
Last Post: locodriver 65
Thumbs Down having trouble Matt 24 10,034 24-10-2014, 06:49 PM
Last Post: Toms306
  trouble after bosch pump upgrade randomcaller 55 26,684 21-10-2014, 09:13 AM
Last Post: randomcaller
