having trouble
Thumbs Down
Having trouble finding the locking point for the crank under the starter, all I know is its a hole under the starter and Hayes just tells you to lock the fly. Can anyone get a picture or a good of what it looks like.
As I turn the wheel I had a look under, can see fly moving and has a square hole at 12 and 6
take your started off it only three bolts the you and get to the hole alot easier
Can you do it without? As I have a tendancy to mess up electrical stuff so would rather not disconect and remove things lol
Modified paint roller XUD fly locking tool required?
Can send you one for £10 posted. Wink
You can do it without removing the starter but probably not if its the first you've done. You don't need to remove wires though, just push the starter back out of the way.
Paint roller for the win!!
Its a round 8mm hole just above a block casting lip.
You wont be able to ser the flywheel moving through it from any angle with engine in the car!
This is what google images threw up:
[Image: 20130404_072445_zpsdfeb3bb5.jpg]
Its a d8a block that but gives you the idea
Right how do I go about removing the starter then? I don't really tend to do much to the car anymore and.my knowledge is shit. Treat me a noob haha
Its just 3 large Hex/Allan bolts on the gearbox side. Cant really miss them lol.
[Image: IMAG3044_zpscb010e85.jpg]
Bastard dont think I have the tools for those. Was hoping they'd be smaller. Only have a basic kit atm seem to have lost a lot of my tools while moving house.lol
Oh dear. Confused
In that case just keep poking around up underneath the starter lol.
As piggy said, and ive said many times..
Get a paint roller, rip the roller and plastic bits off bend the longest bit by handle slightly and itll go straight in without taking starter off lol
My hands are too bloody big for this and I've poked my Allen key into several diffetent holes now. No luck aha
Gunna have to get a helping hand from someone I think.
Have you got a little mirror? Should be able to see and guide it in, paint roller isnt a 100% tight fit so should FIND the hole lol
I'll see if I can find a paint roller. Ironic as I should have one Tongue
Where is the hole in relation to the third starter motor bolt, I've moved the wires and can see down the back of it, can see the end of the rear bolt is it near that?
Heading into town now so I can get a roller lol
Right back from town no rollers :/ what size are the hex? Gunna ask a local garage if they have any tools I can borrow.
Failing that can I lock it any other way?
You can lock the cam and pump.
Why do you want to lock it? Whats being done? Pump change or?
Doing cambelt. Locked the crank off now, but both the cam and pump pulleys don't line up with there holes. Can I lock the bottom and move the other pulleys independently?
No, don't move the pulleys! Confused
It's not locked in the right place if the cam and pump pulleys are out. There are 2 holes in the fly iirc, sounds like you've locked the wrong one.
His timing has slipped though Tom
Ah ok, didn't realise that!
In that case, yes, you'll have to move them independently...
My belt has possibly slipped that's the reason for replacement I have rotated the engine 4 times everytime the lock fot cam is almost there, and then it goes past ever so slightly and click. It's locked on the crank. The bolt to lock of the cam.sits just slightly past the lock. The edge of the bolt touches the edge of the bolt hole. It's the same with the pump exactly the same amount past the pump locking hole
Ahhhh okay so move them once the belt is off. Can I move them slightly anti clockwise or do I have to do a full rotation?
Yep, just move them slightly when the belts off.
Wtf?? I already posted that? Anyhow ill be loosening the tensioner and taking crankpulley off tomorrow after work then sort the belt, should hopefully have it working tomorrow fingers crossed
Strange double post after 2 hours lol
  Still in trouble with Timing. locodriver 65 2 2,596 10-03-2015, 05:20 PM
Last Post: locodriver 65
  trouble after bosch pump upgrade randomcaller 55 26,684 21-10-2014, 09:13 AM
Last Post: randomcaller
  Engine trouble Matt 19 9,032 04-10-2014, 12:45 PM
Last Post: Mattcheese31
