Ball joint/ Hub to strut pinch bolts
I am doing the bearing (on the right side this time lol) and want to replace the two pinch bolts. Does anybody know the sizes needed? I will be using 12.9 cap heads so need the length of the plain shank too. ?
Check ebay. They do them. Brand new in pairs.
theyre extortionate on ebay.
55mm long but longer shank than an sae fastener.
Cheers geezers. Further research has come up with-
BJ pinch bolt-M10x55 with a 20mm shank.
Strut Pinch bolt-M10x65 with a ..... shank.
Will update when I find out more.
(03-01-2018, 06:31 PM)welshpug Wrote: theyre extortionate on ebay.
Iirc I paid £3.50 Inc postage for a pair.
I was happy with that
Servicebox lists the BJ pinch bolts as M10 x 50mm (for HDi estate).  Also 50 on the XSi (18mm BJ's) & they're plenty long enough - replaced them recently.
Strut pinch bolts listed as 65mm length.
https://www.screwfix.com/p/easyfix-brigh...pack/17047
If you want a smaller qty and to upgrade to 10.9's this site is pretty good. Have ordered quite a bit from them now without any issues. Also, if you need anything in fine or extra fine thread, it's worth giving them a bell as they can supply stuff not listed on the site.
https://www.westfieldfasteners.co.uk/BZP...Rpart.html
This site is pretty good too.
https://shop4fasteners.co.uk/hexagon-10-...olour.html
  fitting a front suspension ball joint impotentials 3 3,899 29-10-2016, 05:46 PM
  Bottom ball joint sizes Xsikid 4 3,783 04-05-2016, 05:45 AM
Last Post: Paul_13
  hub pinch bolt spec rd070707 4 3,562 22-02-2014, 07:49 PM
Last Post: swampy
