Shit load of smoke
Shit load of smoke
Hi everyone I was stuck on the m5 yesterday for about 20mins then my car just started cuffing out shit loads of grey Smoke I have a stage one map and intercooler does anyone have any ideas
Thanks Rhys
Is the tonne of smoke only when using the throttle?
Chances are it's probably got a boost leak. Check the usually, jubilee clips, seals etc.
Although, greyish smoke is usually unburnt raw diesel in the exhaust, does the car misfire?
Got no misfire and a small boost leak but that should make the smoke black and was smoking on tickover what sort of psi should I be running ?
Rhys get a video of it and send me / put on here
Yeah I will try tomorrow as need to try and sort it by Sunday before the long drive back . After I got off the phone to you Darren some man who was behind me came next to me undone his window and said I should pull over because it was dangerous for other road users lol
Sounds ike what happened on my Golf when the turbo oil seal popped... Couldn't see anything behind through all the whitish grey smoke...
As above, sounds like turbo oil seals.
How would I check this would I have to take the turbo off ??
(23-01-2014, 10:08 PM)daniel909 Wrote: How would I check this would I have to take the turbo off ??
check for oil in the intake pipes
Ok thanks
And exhaust, if it's grey it's more likely to be exhaust side.
(23-01-2014, 09:31 PM)darrenjlobb Wrote: Rhys get a video of it and send me / put on here
If that's a video, it doesn't work Rhys.
Judging by the pic though, its not looking good!
Oh yeah! awesome.
That's definitely oil burning there. No doot aboot it.
Oh that's bad. Confused
the video would not up load so it just a pic
(24-01-2014, 05:37 PM)daniel909 Wrote: the video would not up load so it just a pic
Theres the tru no smoke no poke lol
Well I have fixed the problem for now give her a good ragging and it has seemed to clear it self Smile
Haha thats pretty heroic
Probably oil sitting in your intake piping.
Rag it more often, and stop granny shifting. Rofl
Probably burnt all the engine oil by now.... lol
But seriously. If you haven't already, do check the level! Just because it's clear now doesn't mean the issue is fixed.
I made a little scratch on my dip stick on Wednesday it still in the same place today
Ah ok, that's good lol!
Got the problem back again
(28-01-2014, 12:03 AM)daniel909 Wrote: Got the problem back again
Lol yeah, reckon you need to fix that! lol
Clutch slipping so going to stick an xud lump in it
(25-01-2014, 09:01 PM)Toms306 Wrote: Just because it's clear now doesn't mean the issue is fixed.
Itwasntme Tongue
XUD swap is easy enough though, good luck. Smile
hdi numbers will be going down at this rate of people putting XUD engines in them.
Hdi running right is a better setup Smile
Doing same as me Wink sacking hdi shit off
[Image: av5ym8.jpg]
  White smoke running shit UPDATED Danny2009 56 22,708 07-02-2014, 08:13 PM
Last Post: mcglynn
  Knock when pulling away and under load titch 18 9,554 15-08-2013, 11:35 AM
  Black smoke with exhaust and egr valve smoke in engine Welshy_Pete 35 22,199 30-04-2012, 09:01 PM
