White smoke running shit UPDATED
Anyone shed any light on this have no idea when it comes to hdi
Got a 307 hdi 110bhp
Starts and idles fine
But when you rev it around 1500rpm it chucks loads of white smoke think its unburnt diesel
Rev it to 2k and it starts missing and nocking like a xud that's too far advanced dosent like going past 2k
Any ideas?
No lights on dash going to check timing but apart from that I'm unsure 100% what it is.
Team Doesn't own a 306
Maybe a f*cked injector/injectors?
Does the smoke smell like diesel? I had this issue sith a f*cked injector although that was at 3k+ rpms.
I was thinking f*cked injector but wasn't sure, yea smells like diesel that's why I am going to rule timing out
Yeah if its not timing its possibly & morr than likely an injector at fault bud.
Shouldnt need to change them all one would sort it!
Not coded to the ecu are they?
Yep white smoke from a diesel is unburnt fuel (often seen when starting if glow plugs aren't working).
I too would be looking at the injectors.
Any way to test them without sending them off or is it a case of buy another and try it?
I don't know if it will throw up any codes but you could unplug one at a time until you find the one thats smoking.
Nooooo dont unplug them, ive read that this can be fatal on a hdi engine.
Dont quote me as I dont know the facts but I would avoid it.
When mine were faulty I changed one by one lol.
(05-02-2014, 10:55 PM)mcglynn Wrote: Nooooo dont unplug them, ive read that this can be fatal on a hdi engine.
Duly noted.
Are you mcglynn from FCF ?
I think I might have signed up & never posted, im not sure lol
I'll get a set orded then and hope it sorts it
You can run a leak off test at idle to diagnose the injectors, if the results vary a lot then generally the injectors are bad.
Usually when the injectors are bad the car will white smoke and chug when started from cold and then go away so it's worth checking the injectors before getting changing them. Is the car standard?
Yea it's standard mate
Dosent really smoke on idle it's just when you give it some revs
Definatley unburnt diesel it stings your eyes
Just doin a leak off test I'll update when it's finished
Looks normal?
[Image: 43C02002-C585-43F7-8C84-BDEA33002F6B_zpsh4y2kaxw.jpg]
Apart from the colour but can't see it giving me these issues
Nice colour hahaha
But yeah looks normal enough,
So.... What the f*ck is up with it!
I would still say injectors bud just due to having the same issues.
The diesel should burn, if it's not then is maybe the compression down?
Also un-burnt diesel means no torque from that cylinder so rough running will be evident too.
HG failure on one of the cylinders perhaps?!
Any signs of bad oil or pressurising coolant circuit?!
Just my quick thoughts.
Dave
Dosent the leak off test rule them out?
Hmm, 3 looks considerably lower than the others, unless it's just the angle of the pic.
Also, what is that colour from? Wonder if something odd has been put in the tank to upset it?
There all the same within a few mm
It's red diesel tom Smile
Ah I see lol. Isn't red diesel less well filtered as its meant for agri use? Possibly water in it?
Depends red can be clean it's when people pump it from the diesel pump into dirty drums and pour it in the car
I've left the bottles to sit so will see if there's water in it
But it's white unburnt diesel smoke
Can't be glow plugs as I left it running half hour and it was still smoking
Engine sounds really ticky so could be injectors?
Agricultural use i imagine.
Ok fair enough. Can you not get diagnostics or PP on it? Doesn't have to be a fault light for a fault code to be stored. And PP will obviously show specific readings.
Another thought though, is the EGR stuck open? If it's allowing exhaust in at higher rpm under load it'll lack oxygen and overfuel. I've currently got this issue on the Vec but the effect isn't as bad as yours sounds.
If egr was stuck wouldn't engine management light be on?
Not sure tbh, it doesn't bring the light on on 306 HDis.....
Worth a check I'll have so go at that tomorrow
Cheers Smile
  white smoke from starter motor apples76 12 6,900 17-07-2017, 05:05 AM
  White smoke LewisG 8 4,797 22-05-2014, 06:18 PM
Last Post: LewisG
  Big bang and lots of white smoke tinysomniac 18 15,090 31-01-2014, 12:13 PM
