Brake lights and dash lights after
Noticed my brake lights wasn't working earlier. All other lights are fine apart from these. Checked the bulbs they was fine then my dash lights have gone. Could it just be a fuse? I checked the fuses under the bonnet but it seems the ph1 just has relays instead of normal fuses
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Maybe an earth problem? I guess the brake light switch and dash illumination will use the same earth.
Cant be a fuse if they both failed at different times.
Problem sorted
Ph3 perv cab heaven
Black ph1 XUD died
Might be useful for future reference to know how you sorted it lol?
Ok. If you ever have to change he matrix don't forget to plug the switch in lol
Ph3 perv cab heaven
Black ph1 XUD died
Lol, at least it was an easy fix then!
  Fog lights, new bulb ROBCAT 0 2,518 14-06-2018, 09:11 PM
Last Post: ROBCAT
  No brake lights Beb 2 3,249 01-06-2018, 05:23 PM
Last Post: cully
  Lights always on. luke306rallye 14 10,932 30-12-2017, 10:29 AM
Last Post: luke306rallye
